> The Wonders of Science, estimating engine power
lapuwali
post Jun 18 2004, 03:50 PM
Not another one!
A few years ago, when I still raced motorcycles, there were a number of jokers who ran a team called The Army of Darkness. Not Satanists, just troublemakers. They wrote up a series of great technical articles referring esp. to a now dead engine designer named Phil Irving. Irving divulged the following simple formula:
cyl size / (valve_size * lift * pi * valve_count) * ((rpm/2))/60
This gives the mean gas speed through the intake tract, which, when crunched against the stats for a wide variety of bikes they available, turned up the fact that the maximum gas speed for a normally-aspirated engine was about 12.5m/s. Above that gas speed, power always falls off, presumably because at that point, more airflow simply doesn't happen (sonic wall). This means that the formula above can show what the max USEFUL revs will be for given valve sizes and lift. This worked on every bike engine they tried (and a few they didn't, which I did later).
Today, with some time to kill, I tried the Type 4. I have a 1.7, so that's what I used. 1679cc, so 419.75cc per cylinder. Valve sizes are 39.33mm, and there's one intake per cylinder. Lift I didn't know for the stock cam, but a troll through some other references suggested it was somewhere between 10-11mm (at the valve, not the cam). I tried the above for 10mm, and BING! max gas speed at 4500rpm is 12.7m/s. 4500rpm is the power peak for a stock 1.7. Looks like this formula works for the Type 4, too.
What else can we find out? Well, hp = torque * rpm / 5252. Increase engine speed w/o altering torque and power rises. Problem is, if the engine doesn't breathe at the elevated engine speed, torque drops off, so power drops off. If you can raise the engine speed w/o harming breathing, you'll get more power.
Well, with 42mm valves (stock for the 2.0) and the 10mm lift, the power peak only rises to 4700rpm. This suggests only a mild power increase (about 4%). With a cam/rocker combo giving 12mm of lift, however, the power peak rises to 5700rpm (26%). With the cam alone and stock 1.7 valve sizes, the power peak rises to 5300rpm (18%). This suggests that with 2.0 heads and a 12mm lift cam, you can get 100hp out of a 1.7. With just the cam, you can't do better 95.
All of this ignores a whole host of other factors, but it's interesting that first order approximations seem to work. It's esp. interesting that Irving wrote this work in 1948, and it still works today.
Replies(1 - 7)
airsix
post Jun 18 2004, 04:28 PM
I have bees in my epiglotis
Before anyone jumps in to say "Ya, but..." I just want to say thanks for posting this. I think it's pretty cool stuff.
-Ben M.
post Jun 18 2004, 04:41 PM
Resident German
QUOTE(lapuwali @ Jun 18 2004, 02:50 PM)
"The Army of Darkness" is the title of one of the movies out of the "Evil Dead" series ...
those are my all time favorite *horror* movies, i'm chuckling right now just thinking about how bad those movies are.
nothing like a horror movie that is supposed to be scary but you can't help but laughing your ass off.
priceless classics ...
now back to the topic on hand!
(IMG:style_emoticons/default/biggrin.gif) Andy
ChrisFoley
post Jun 18 2004, 04:48 PM
I am Tangerine Racing
A while back I ran a 1.7L (91mm bore) race engine with 1.8L valve sizes that dynoed (Dynojet) at 120 RWHP from 6000-6500 rpm. I estimate that would be more than 140 BHP.
The max lift of the cam was about 12.5mm.
My current 1.8L (94mm bore) engine dynos at 125 RWHP around 6200 rpm with a Webcam 86a which has max lift of 11mm.
lapuwali
post Jun 18 2004, 05:55 PM
Not another one!
So, Chris provides some data and blows the whole thing up. The 1mm oversized 1.7 with the 1.8 valves (presumably the 41mm versions) and a 12.5mm lift cam should run out of breath at 5700rpm according to the approximation formula. Yet, it kept going to 6500. It also produced a lot more than 25% more power over a stock 1.7. Like I said, lots of other factors, too, like compression, are ignored. Exhaust factors are totally ignored with this. I'm completely uncertain about the idea of simply using the % revs increase to guesstimate power, as well. It certainly doesn't work in this case.
Mueller
post Jun 18 2004, 05:59 PM
914 Freak!
it could be just for estimating baseline hp or the minimum it should produce ideally....not maximum power
ChrisFoley
post Jun 18 2004, 07:02 PM
QUOTE(lapuwali @ Jun 18 2004, 07:55 PM)
Other performance oriented things done to these engines included massaged 40mm carbs with big venturis, high compression, significant port work, valve springs, Tangerine exhaust.
The intake valves are 41.9mm, max allowed by the rules.
Everything was done in order to help them breathe better at high rpm, and this all comes with a big sacrifice to low end torque. I consider the mid-range to be around 4500-5500 rpm on these engines.
On the current engine's dyno graqh the torque actually drops 7 lb-ft between 3700 (the dyno curve starts there) and 4250 rpm then climbs to a peak of 120 lb-ft at 4900 rpm.
Like Jake loves to say, "It's all in the combo!"
lapuwali
post Jun 18 2004, 07:28 PM
Not another one!
Another amusing estimation formula is to look at Brake Mean Effective Pressure (BMEP), which is the average combustion pressure during the entire combustion cycle. This is related to power roughly this way: (engine size (in cu. in.) * rpm * BMEP)/793,000 = hp. A really good race engine will have a BMEP approaching 200psi. An average road car will have a BMEP around 125psi.
BMEP peaks at the torque peak. With a torque peak of 4900rpm, and a torque figure of 120ft/lb, and the relationship of torque, hp, and rpm given earlier, we have 111hp at 4900rpm, for a BMEP of about 165psi, which is pretty decent for a streetable engine. With a power peak of 6000rpm (and BMEP will fall past the torque peak), we can guesstimate that a BMEP there of 150psi would give a power figure of about 125hp. If it managed to hold the 165psi all the way to 6000, it would be 135hp.
Funny, I was dreadful in math at school, and these days I spend a lot of time fooling around with formulae like this.
- Lo-Fi Version Time is now: 7th July 2025 - 12:27 AM
