> air fuel ratio meters, Anyone have much experience using these on D-Jet
914Mels
post Jul 4 2011, 02:07 PM
(IMG:style_emoticons/default/sawzall-smiley.gif) I'm looking to fine tune the injection on my '70 914 and am considering a LM-1 meter to take out the guess work. Has anyone done much work with one of these? Or suggest a different model meter?
Replies(1 - 19)
Mike Bellis
post Jul 4 2011, 03:57 PM
Resident Electrician
The LM-1 is a good unit. AEM and Autometer make them too with gauges to mount on the dash. Not much fine tuning can be done on early FI systems. You can tune it but not fine tune it. The system runs on internal fuel maps and they are not accessible.
Dave_Darling
post Jul 4 2011, 04:23 PM
914 Idiot
Heh, the system doesn't even rely on fuel maps at all! It uses the amount of time for an electric current to induce a current in another coil of wire (inductive coupling) as the basic metering time!
Read up at http://members.rennlist.com/pbanders -- Brad Anders has a lot of D-jet info, including suggestions about ways that it can be tweaked and possibly (if you're lucky) tuned.
--DD
914Mels
post Jul 4 2011, 04:56 PM
QUOTE(kg6dxn @ Jul 4 2011, 02:57 PM) *
Thanks for the reply, I wasn't sure who would be here on the 4th. The 914 monkey on my back won't let up, holiday or not. I want to fool the ICU, fuel pressure up or down, experiment with some variable resistors for the temp senders to get closer to a better mixture. I'm hoping to "see" where the engines at and not create any problems just randomly modifing and hoping for a improvement.
brant
post Jul 4 2011, 05:45 PM
I've used an LM-1 to adjust MPS units to fit the motor
also if you planned on tweeking resistors, or fuel pressure, the LM-1 would give you a good picture of which way and how far you were going.....
Strudelwagon
post Jul 4 2011, 05:56 PM
QUOTE(Dave_Darling @ Jul 4 2011, 03:23 PM) *
--DD
When I got my 2.0 a few years ago the PO had installed a little reostat with toggle switch that I believe can richen or lean out the fuel. Some old autocrosser black magic??
Wired directly to the ECU.
SW
914Mels
post Jul 4 2011, 06:00 PM
QUOTE(brant @ Jul 4 2011, 04:45 PM) *
Yeah, that's what I'm trying for. The injection is stock, 1.7, the motor has 93's from a 1.8 and the cam is a unknown hydraulic grind that was put in years ago. So I figure the original fuel map is probably off a bit. Once I get this rolling, I'll post some results. Anyone have a gently used meter for sale?
brant
its been done a lot
but the wideband will tell you how much to turn the knob
AFR isn't like a boost knob
there is a range and its not a wide one, where it will run right
beyond that you loose HP, and on the lean side you do damage...
really once you get it dialed in you should leave it alone.
if you were going to tune for altitude, humidity (beyond the factory compensation) you would need the wideband to see what you were doing.
brant
914Mels
post Jul 4 2011, 06:36 PM
QUOTE(brant @ Jul 4 2011, 05:00 PM) *
its been done a lot
brant
That's the plan, get the modifications dialed in and replace the variables with some fixed resistors. Thanks to everyone who chimed in, I will have a beer in your honor. (IMG:style_emoticons/default/beer3.gif) Mike
ConeDodger
post Jul 4 2011, 08:40 PM
Apex killer!
Remember to sample under load. Neutral revving numbers are no bueno...
914_teener
post Jul 5 2011, 11:03 AM
QUOTE(914Mels @ Jul 4 2011, 05:00 PM) *
This is interesting. I would be very interested in your results. I was thinking of doing the same.
sean_v8_914
post Jul 5 2011, 11:22 AM
Chingon 601
LM1 can be found at a discount since they came out with LM2 in color
914Mels
post Jul 5 2011, 11:38 AM
QUOTE(914_teener @ Jul 5 2011, 10:03 AM) *
I'm pricing meters, found one on Amazon for $229. That seems pretty fair for what you get. I'm glad I found this web site, there is a ton of info here that isn't easily available out of a repair manual. I've spent some time checking all the basics out first, to get a true baseline. Had a leaky MAP sensor and one dead plug wire resistor. We'll see how far off things are from here. Mike (IMG:style_emoticons/default/driving.gif)
Maltese Falcon
post Jul 5 2011, 09:38 PM
Mike, I'm using the unit from Nordskog Instruments . It's easy to install and has a 2 1/16" gauge face , you can put it just about anywhere. I mounted it off of the knee bar on the roll cage.
Marty
brant
post Jul 5 2011, 10:59 PM
nordskog makes some good stuff
and their customer-tech service is top notch
I have a bunch of their stuff in one car:
also.. Innovate makes a great AFR
I've run it for years now...
914Mels
post Jul 6 2011, 05:44 PM
I like your dash install, I'm not sure I want to permamently mount one in the car. If I can see the readings all the time while I'm driving, I may drive myself crazy trying to "perfect" every load and driving condition. I'm hoping to spend a few hours at a time and dial in the worst of the results untill I run out of options. Thanks to everyone for all the imput.
Mike Bellis
post Jul 6 2011, 07:42 PM
QUOTE(914Mels @ Jul 6 2011, 04:44 PM) *
Don't worry. You wont be able to perfect the factory FI. You will need to switch to a programmable EFI system to get the desired results.
914_teener
post Jul 6 2011, 11:17 PM
QUOTE(kg6dxn @ Jul 6 2011, 06:42 PM) *
What FI system would you suggest?
Mark Henry
post Jul 7 2011, 09:21 AM
that's what I do!
Just an FYI this is the JAW wideband, it's a DIY kit. $140 plus $50 for the bosch O2 sender.
http://14point7.com/SLC-DIY-2.php
Bleyseng
post Jul 7 2011, 11:25 AM
Aircooled Baby!
Factory Djet is close enough for a hydro cam 914..as the cam timing is mucked up by the ramps compared to a solid lifter cam which has better cam timing.
use the LM1 to set the "partload" to 13.5/14 to 1 AFR at 2500rpms driving at a steady speed up a long slight uphill road in 3rd gear. Check it at freeway speeds to get it to hang around 13.5/14 driving in 5th gear at speed up slight slopes as if you are coasting (off throttle) its no good. You want a steady throttle at a steady speed with slight load.
Then check the Wide open throttle settings- those should be in third gear at 10-15mph punch it and see. It should start at 11/11.5 to 1 to start and all the way up to 5000 rpms slowly lean out to 13.5 to 1. This is adjusted with the large machined plug witch you have to remove undamaged to get to the inner screws to adjust the part load.
Finally, check the idle as it should be to 13.5 to 1.....
First off, make sure the engine is in top tune, valves adjusted, no vacuum leaks and Fuel pressure adjusted to 29lbs.
- Lo-Fi Version Time is now: 2nd April 2026 - 03:38 PM
