DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
I have a 75 2.0, with 8spoke empi 15" 4 lug, and 195/55 performance tires. Currently have bilistein sport shocks, adjustable with newer #100 springs. When set higher to give better clearance its pretty bouncy, so I moved them down 3 notches to take tension off springs but before I rolled the fender lips they would have almost zero clearance on outside.
Would going to #140s help. I know there is an inch diff in height so if I put the shock setting higher- more pressure on the spring I will get a little higher ride, but will it be too stiff for daily driving and the occasional d.e. on the road course- robeling road? It should bounce less but . Anyone used this combination? I've not had the #140s but have a chance to buy some. Need some I.put to make a decision on this. Thanks Phil I also have stock sway bar with new bushings |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
100 (IMG:style_emoticons/default/wink.gif)
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
That's funny! (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 17th June 2024 - 05:47 AM |
