| 913B |
Jul 31 2011, 08:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 864 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
So the continuing saga of fitting the SS heat exchangers continue. I somehow pulled out the heli coil repair on the exhaust stud. The coil measures 9.5mm OD.
I suppose I need to re-tap the hole with a step stud. So what size step stud should I use ?? M8 to (M10 or M11) ? Where would I find such a stud ? Is it do-able, drilling and tapping from under the engine ? How the heck am I going to keep the bit and tap straight and not F/up ? Man it never ends with old cars...... (IMG:style_emoticons/default/ar15.gif) Thanks in advance for everyones help !!!! I really appreciate it. (IMG:style_emoticons/default/beerchug.gif) ![]() ![]() ![]() |
| turnaround89 |
Jul 31 2011, 08:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Its not that same area, however, i just had the threads on an intake stud strip out and i used a timesert, extremely simple, a little on the expensive side because you buy a whole kit when you use one but it worked really well. These might work better than a helicoil.
| Mike Bellis |
Jul 31 2011, 08:23 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
You need a time-sert. Search ebay. Way better than helicoils.
| HAM Inc |
Jul 31 2011, 08:44 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 850 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
Your best bet now will be to get a M10x1.5 Time-Sert or Heli-Coil kit. This will allow for the installation of a M10x M8 step stud. The O.D. of the Time-Sert/Heli-Coil will be ~12mm. This is required now that you have pulled out a M8 Heli-Coil which, as you can see, has a ~10mm O.D.
Attempts to tap for a M10 stud only (no insert) will fail as the hole is already to large for this. A M10 tap requires a .325-.340 tap. Keep in mind that drilling to deep will punch into the cylinder itself and the head will have to come off if this happens. Also keep in mind that the repair you are about to make is pushing the limits of material that the stud boss will support. This is the end of the road as far as repairs that don't require welding. I would be hesitant to hit the road with a repair of this sort. This may be a stop gap that buys you time, but head work is likely in your future. This sucks for you! And it's the reason I do not install inserts in T4 heads I reman. All repairs are weld repairs with M8 threads tapped. That way if a field repair is ever required there's something to work with. Good luck. |
| iamchappy |
Jul 31 2011, 08:50 PM
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
i went through this, i fixed it with a very stout ezloc, i doubt i will ever have a problem
with it, plus there inexpensive and easy to install, and removable..... http://www.ezlok.com/InsertsMetal/index.html http://www.ezlok.com/InsertsMetal/threads-uncExternal.html |
| KaptKaos |
Jul 31 2011, 08:57 PM
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Be careful with the step-stud. You need to make sure that the angle of the new hole + tap = the angle of the original. Or, it will not seat properly on the header.
Ask me how I know..... |
| sean_v8_914 |
Jul 31 2011, 08:58 PM
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
ouch, Hoffman laid that one out nicely.
| KaptKaos |
Jul 31 2011, 09:01 PM
Not trying to 1-up Len. Just trying to add to the conversation. I certainly don't have the expertise to contradict Len.
| sean_v8_914 |
Jul 31 2011, 09:05 PM
I use a fixture t ensure the holes and tap threads are on the correct angle
PS. heli coils are evil |
| Woody |
Jul 31 2011, 10:14 PM
Sandbox Rabblerouser and head toilet scrubber ![]() ![]() ![]() ![]() Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
The picture looks like a time cert. It has a shoulder.
| 913B |
Jul 31 2011, 10:22 PM
dam that time sert pic from ebay looks like exactly what was pulled out. I guess I dont know what I actually had. It wasnt an heli-coil after all. Might look into that ez lock.
| 913B |
Jul 31 2011, 10:23 PM
| Cap'n Krusty |
Jul 31 2011, 10:46 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
You won't like this, but read it anyway. Remove the head and have it welded, machined, drilled, and tapped. There's a REALLY good chance the threads and inserts are going away because the head is cracked. Be sure they fix ALL the cracks. Plan on spending a lot of money.
BTW, there's NOTHING wrong with Helicoils if they're used as intended. They WON"T fix weakened or cracked base material, nor will any other brand/type of insert. The Cap'n |
| 913B |
Jul 31 2011, 11:16 PM
Dam it. I dont think I have the minimum 9/16 depth for the ez loc. I have to crawl back under the car and check. This really sucks !!!!!!!!!!! (IMG:style_emoticons/default/sad.gif)
| rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,447 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
QUOTE Your best bet now will be to get a M10x1.5 Time-Sert or Heli-Coil kit. This will allow for the installation of a M10x M8 step stud. The O.D. of the Time-Sert/Heli-Coil will be ~12mm. This is required now that you have pulled out a M8 Heli-Coil which, as you can see, has a ~10mm O.D. I did this a couple of years ago with the engine in the car. Go slow, get the angle right and measure the depth ahead of time so you don't go too deep. One of the hardest parts of the job for me was finding a correct step stud. I had to mail order from Canada. No one had 'em or if they did the threads were cut incorrectly. Good luck! |
| HAM Inc |
Aug 1 2011, 07:06 AM
QUOTE You won't like this, but read it anyway. Remove the head and have it welded, machined, drilled, and tapped. There's a REALLY good chance the threads and inserts are going away because the head is cracked. Be sure they fix ALL the cracks. Plan on spending a lot of money. BTW, there's NOTHING wrong with Helicoils if they're used as intended. They WON"T fix weakened or cracked base material, nor will any other brand/type of insert. The Cap'n Everything The Cap'n said is correct. I've seen a gazillion of the cracks he describes. That said, I examined the photo and it appears that you may just have a stripped boss. Hard to be 100% sure, but that is my hunch. And there is nothing wrong with Heli-coils if they are installed correctly. The biggest mistake is poor threading, regardless of the insert type. It's a touch task laying on your back to get it right. An unsteady hand will make a larger thread. The biggest drawback to the heli-coil is that it can be difficult to install in certain situations, like this one. If you have been living right and you do a perfect insert installation the unit may just stay put. If it doesn't you are facing removing the head. I can sell you a M10 x 8 step stud. My supply of the damn things is dwindling but I can spare one for a forum member in distress. It will be M10-1.5 x M8-1.25 I may be wrong about this, but I believe the EZloc requires a larger hole than the time-sert or heli-coil. If that is the case I would not consider it for this job as you are about out of boss material. A bit of advice that may sound counter intuitive, but trust me on this. Before you install whatever insert you decide to use slather both sides of that baby with copious amounts of copper anti-seize. Copper because it will stay put at higher temps without turning to paste like the silver kind. This will help keep the threads from corroding and increase the odds that the insert won't pull out over time. The Time-Sert will be much easier to install in this situation than the heli-coil. |
| 913B |
Aug 1 2011, 08:07 AM
I don't drill too straight let alone run a tap straight while on my back.
Do you reccomend removing the head in the car or out of the car ? What is more feasible, taking the head to machinist to weld and check for cracks around the stud bosses OR get another used head. But then what is needed to mate the used head to my block ? Which route is most feasible would you guys reccomend ?? |
| HAM Inc |
Aug 1 2011, 08:36 AM
Because of the proximity of the ex seat to the stud boss simply welding the boss and remachining (which needs to be done on a mill on a fixture for accuracy) is not a good idea. The welding causes distortion to the seat counterbore and can/likely will lead to a dropped valve seat.
The right way (and the only way I approach this situation) is a total remanufacturing of the heads. Anything short of that is patch work. Doing a little work here (welding) and a little work there (replacing one valve seat) but not doing a complete job will have you revisiting other issues at some point in the future. Once you make the decision to pull the head, my advise is to pull both. Have them properly gone through, put the thing back together and don't worry about head issues for a very long time. There are shortcuts and many people have tried them. Some have gotten lucky, many have not. You have to ask yourself, "Do I feel lucky?" |
| jcd914 |
Aug 1 2011, 01:40 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I have never used E-Z LOK inserts so I can't recommend or warn against them but I was looked at their site and found the drill/tap sizes.
If I was looking at pulling heads and having them rebuilt or trying to save 1 while on the car? I would look close at how bit the hole in the head is. An 8mm thread repair requires a 10.4mm drill and a 12mm tap, you might be able to get away with that and avoid the step stud. Just a thought. Jim For 8mm x 1.25mm thread repair: E-Z LOK Part No. 453-8 Internal Thread M8-1.25 External Thread M12-1.75 Length mm 12.5mm Tap Drill Size 10.4mm Tap Size M12-1.75 Minimum Full Thread Depth 14.5mm Drive Tool Catalog No. 500-4 For 10mm x 1,5mm thread repair: E-Z LOK Part No. 453-10 Internal Thread M10-1.5 External Thread M16-2.0 Length mm 17.0mm Tap Drill Size 14.0mm Tap Size M16-2.0 Minimum Full Thread Depth 19.0mm Drive Tool Catalog No. 500-5 |
| HAM Inc |
Aug 1 2011, 01:51 PM
The M8 EZ lock O.D. is ~ the same size as the M10 Time-Sert and Heli-Coil.
Since the EZ lock uses a std 1/2 tap it looks like for this specific situation it would be the way to go. No pricey kit to purchase. Just the tap and an insert. When finished you can use a typical M8 stud. I'd be inclined to give it a try before I pulled the head off. It might just hold up fine. If it doesn't work at least you won't have much invested. |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:42 PM |
