12 CFM's at 45 PSI?, Paint pro advise |
pete |
Aug 16 2011, 12:00 PM
Member Group: Members Posts: 158 Joined: 23-August 10 From: New Jersey Member No.: 12,092 Region Association: North East States |
I've never painted a car before. I was planning on purchasing http://www.harborfreight.com/high-volume-l...-gun-66222.html. The manual states it uses 12 CFM's at 45 PSI. I have a Craftsman 20 gallon compressor. I haven't checked the max CFM yet but I have a feeling it is around 7CFM's. Will this gun work with my compressor for priming and painting my 914?
scotty b |
Aug 16 2011, 12:04 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
I've never painted a car before. I was planning on purchasing http://www.harborfreight.com/high-volume-l...-gun-66222.html. The manual states it uses 12 CFM's at 45 PSI. I have a Craftsman 20 gallon compressor. I haven't checked the max CFM yet but I have a feeling it is around 7CFM's. Will this gun work with my compressor for priming and painting my 914? Yes it will work, your compressor wil just kick in and out fairly often. No more so than a d.a. would make. You need to find out what tip size the gun has. I didn;t see that anywhere in the description. To shoot primer through a small tip you will need to reduce it it down, and if the tip is large I wouldn't suggest putting your top coats through it. 1.7 is best for normal primers, a 1.3 or 1.4 for your colors and clears. A 1.5 could do all with good results provided you thin the primer a bit. |
r_towle |
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
yes, but the compressor will run all the time, and you really need to paint slower, and take more breaks to let the compressor catch up.
I have painted with smaller compressors...its not great, but for one car, it can be done. Rich |
andys |
Aug 16 2011, 12:15 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
I have that very same gun, and a 20 gal Craftsman 2HP compressor. I can outrun the compressor when doing a larger area, but it will catch up reasonable quick and has never been an issue for me. I run 15-25 psi at the cap; maybe a bit more for primer, but not 45 psi as you'll get too much bounce-back. Go by the paint manufacturers recommended cap pressure. BTW, that gun works as well as my expensive Eastwood Concourse gun.
Andys |
underthetire |
Aug 16 2011, 12:34 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Make sure you de-burr and clean the tip. Mine wouldn't work right, found sharp edges in the air port of the tip and some brass blocking the air port hole. After that it sprayed fine. Here's a coupon if you need it.
http://widgets.harborfreight.com/wswidgets...mp;keycode=1002 |
pete |
Aug 16 2011, 12:46 PM
I have that very same gun, and a 20 gal Craftsman 2HP compressor. I can outrun the compressor when doing a larger area, but it will catch up reasonable quick and has never been an issue for me. I run 15-25 psi at the cap; maybe a bit more for primer, but not 45 psi as you'll get too much bounce-back. Go by the paint manufacturers recommended cap pressure. BTW, that gun works as well as my expensive Eastwood Concourse gun. Andys Thanks for the advise everyone. I did a little more research on HF and ordered this one http://www.harborfreight.com/20-oz-high-vo...-gun-47016.html Runs a little lower on the CFMs, was cheaper, came with a 1.5mm tip which seems an all around good size ( have no idea what size tip the other one comes with, tech support didn't know either) and you can purchase other size tips separately from HF. Got great reviews to boot. Ordered all the necessary accessories as well. Thanks for the coupon too! |
andys |
Aug 16 2011, 01:47 PM
Thanks for the advise everyone. I did a little more research on HF and ordered this one http://www.harborfreight.com/20-oz-high-vo...-gun-47016.html Runs a little lower on the CFMs, was cheaper, came with a 1.5mm tip which seems an all around good size ( have no idea what size tip the other one comes with, tech support didn't know either) and you can purchase other size tips separately from HF. Got great reviews to boot. Ordered all the necessary accessories as well. Thanks for the coupon too! The first gun you posted is slightly better quality (The first gun has a 1.4 tip) and has a regulator at the gun where as the second one does not have the regulator and is of slightly lesser quality (as far as HF guns go). I have both of these HF guns, and use the cheapie for high build primers (though I modified the tip). BTW, it's best to have the regulator at the gun in order to set the cap pressure; makes it easier and more accurate. Pull the gun trigger to air only, and then set your pressure. Scottyb gives some good advice. I found the 1.4 tip to be pretty darned universal in the end, and reducing the paint to work with the tip seemed to work out as well as selecting the tip to the paint.....It's not an exact science. I have 1.2 and 1.7 tips for the Eastwood, and never used them. Andys |
Andyrew |
Aug 16 2011, 02:43 PM
That second harbor freight gun is junk. I have tried 3 of them. They pale in comparison to the better gun that I have. After a short amount of time they start to spray funky. There are only 2 little holes to control the air spray on the tip and they really do a poor job at it.
That first one looks a lot similar to what I am currently using. I really think you should have went with that one.. Check out these guns. http://www.tcpglobal.com/spraygundepot/tcpgate.aspx Im highly considering getting one of Devbliss's starting line guns http://www.tcpglobal.com/spraygundepot/finishstart.aspx |
Lo-Fi Version | Time is now: 10th June 2024 - 03:07 PM |
