PBC914 |
Member ![]() ![]() Group: Members Posts: 192 Joined: 30-December 10 From: Minneapolis Member No.: 12,545 Region Association: Upper MidWest ![]() |
I have a 75 1.8 that I thought was having an issue with the fog lights. Until I realized that the reason the fogs weren't working while the headlights were on, is that the fog lights don't work with the high beams on.
When the headlights are turned on, I cannot switch off the high beams using the turn signal. The high beams remain on all of the time. It won't click on or off. Any ideas? Is the turn signal arm possibly broken? |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Bad hi/lo relay. The fog lamp relay gets its ground from the High beam hot. But only when the high bean is off. I beleive its a blue/white or white/blue attached to the high beam fuse. If you ground that wire the fogs will work with both high and low.
PBC914 |
Thanks for the quick reply!
Lo-Fi Version | Time is now: 10th June 2024 - 08:06 AM |
