Relay Board, New, Used, Reman |
bbrown |
Aug 23 2011, 11:34 AM
Member Group: Members Posts: 92 Joined: 23-December 04 From: ohio Member No.: 3,330 |
Besides the Bird folks, does anybody have good ones and if so how much?
type47 |
Aug 23 2011, 12:38 PM
If you suspect yours is bad, it's easy enough to verify all the current paths with a continuity tester (many Digital Volt Meters have a setting where a sound is emitted if the current path is good). I've seen relay boards on ebay around $25 (no affiliation, buyer beware, etc). You could post a WTB in any of the for sale sections if that's the way you want to go.
SirAndy |
Aug 23 2011, 12:58 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
SirAndy |
Aug 23 2011, 01:05 PM
Tom |
Aug 23 2011, 02:11 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
I got one from someone on here in the classifieds. It cleaned up great and all circuits tested ok.
Be careful using a beeper on a digital volt/ohm meter. They will beep when you have several ohms of resistance. From the pins to pins on the relay board. all readings should be less than 1 ohm, should be almost 0 ohms. Touch the leads together first to see what the leads are reading and use that for your "0" reading. Tom |
jmmotorsports |
Aug 23 2011, 03:02 PM
Member Group: Members Posts: 308 Joined: 15-August 06 From: Kelso,Wa. Member No.: 6,658 Region Association: Pacific Northwest |
Lo-Fi Version | Time is now: 31st May 2024 - 07:14 PM |
