External size 6 cyl. engines 2.0 six vs. 3.0 |
xsurfer |
Aug 30 2011, 05:18 PM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
I'm trying to find out if there is an external size difference in engines.
Does anyone know |
Cairo94507 |
Aug 30 2011, 05:36 PM
Michael Group: Members Posts: 9,826 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Same size engines just bigger pistons and cylinders I believe.
bcheney |
Aug 30 2011, 05:53 PM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
Correct.. all air-cooled flat six Porsche engines from 2.0 - 3.6 are the same in external dimension and fit into the 914 engine bay.
Cap'n Krusty |
Aug 30 2011, 06:11 PM
Didn't I jut answer this question for you yesterday? 2.0 through at least 3.2 are the same width.
The Cap'n |
RON S. |
Aug 30 2011, 06:14 PM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Correct.. all air-cooled flat six Porsche engines from 2.0 - 3.6 are the same in external dimension and fit into the 914 engine bay. I can second that. on my original 6, the original 1970 2.0 motor mounting bracket bolted right up to my 1995 3.6l engine currently install. 25 years, and still the same basic dimensions and bolt patterns. Ron |
Elliot Cannon |
Aug 30 2011, 06:18 PM
I believe the cooling tin on the 3.6 is a bit different. All the rest are the same. Correct Cap'n?
Series9 |
Aug 30 2011, 06:24 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
Yes. 2.0-3.6 are all the same external dimensions, the FI on top is a different story.
MFI fits without a problem. CIS is a tough fit. The engine needs to be lower or the trunk needs to be cut. The Motronic on a 3.2 does fit, but it's tight. Most remove the stock air box. The Motronic on my 3.6 fit after I removed the crossbar on the engine decklid and moved some of the intake plumbing. 3.6 Varioram does not fit without modifications to the body. |
Jeffs9146 |
Aug 30 2011, 06:30 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
QUOTE CIS is a tough fit. The engine needs to be lower or the trunk needs to be cut. Not nessesarily! I didn't cut my trunk or lower the engine. I modified the air box so everything could fit without cutting for a 3.0L FI! Attached image(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 10:20 PM |
