Got crap in the fuel system, How far do I need to go? |
ellisor3 |
Sep 10 2011, 10:31 AM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
I was driving yesterday and suddenly it sputtered and cut off. Would not restart. I thought maybe I was out of gas since my gauge was bouncing around. I wasn't far from home and got a gas can and added 2 gallons. Still would not start.
I drained the tank this morning and it had about 4 gallons in the tank. The gas from the tank looked ok. When I went to the filter at the engine and drained it, I got a nice shade of rusty brown and there was a lot of grit about the texture of sand. I drained all of the lines and will replace the filter. How far should I go? Do I need to clean the injectors as well? Take off the fuel rails? What about the fuel pump? BTW, It is a 3.2 |
dirk9141973 |
Sep 10 2011, 11:02 AM
Unregistered |
I was driving yesterday and suddenly it sputtered and cut off. Would not restart. I thought maybe I was out of gas since my gauge was bouncing around. I wasn't far from home and got a gas can and added 2 gallons. Still would not start. I drained the tank this morning and it had about 4 gallons in the tank. The gas from the tank looked ok. When I went to the filter at the engine and drained it, I got a nice shade of rusty brown and there was a lot of grit about the texture of sand. I drained all of the lines and will replace the filter. How far should I go? Do I need to clean the injectors as well? Take off the fuel rails? What about the fuel pump? BTW, It is a 3.2 Start at tank and work to filter that was my problem once rust starts moving (IMG:style_emoticons/default/sawzall-smiley.gif) |
skaufmann |
Sep 10 2011, 10:34 PM
Blissfully Ignorant Group: Members Posts: 103 Joined: 26-May 11 From: San Diego - College Area Member No.: 13,123 Region Association: Southern California |
Kind of went through this.
-Pull the tank out, not too hard (you will need to replace the soft lines under tank). I assume since you have the filter in the back (like me) you have an earlier version with the pump behind the firewall. If so once you have center tunnel lines open on each end, blow air through the lines. -Some will tell you to replace center lines with stainless. If you move pump to front you should replace with SS lines. If you leave in back not required since you're dealing only with negative pressure on supply and *neutral* pressure on return. -Replace fuel filter (make sure filter is on supply line before the pump). -Flush all loose material from tank. All tanks will have rust. What you should be most concerned about are *issues*. That's vague but you don't want to see areas that have more problems than others. If it's pretty consistent and tanks walls appear thick, you'll be fine letting it dry out and fill with gas again. Some will tell you to get taken care of at a radiator shop who will acid bath and seal the tank. This is true but not necessary if the tank only has normal rust. Again all original tanks have rust and work just fine. -Reassemble everything and run pump without running engine which will *flush* the rest of the lines and get the new filter to catch any rust floating around. Another new filter could easily be installed after that. NOTE: you can get the pump to run by pulling the relay and bridging 2 of the connectors. I don't know which numbers just visually. (might be 30 and 78 but they are at 12 o-clock and 7 o-clock with 12 being front of the car) -also, replace the sock filter in the tank on the supply line (bigger line). Hope that helps. |
McMark |
Sep 11 2011, 11:46 AM
If you can stand to leave it on jackstands that long, I would do as much as possible. You'll then KNOW that the fuel system is 100% and never have to worry about it again. If you get the injectors cleaned then your engine may run better (if they weren't great already), so there is a 'side' benefit to doing it all.
And finally, I know you already did research on this and PMd me about it, but for future readers of this thread, I recommend this epoxy tank sealer. I've heard of other brands peeling away from tank walls and this stuff becomes a permanent part of the tank. I use it an nothing else for tank resealing. |
Drums66 |
Sep 11 2011, 02:56 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
......yeah..I'm down with cleaning the whole system...to be sure! (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif)
(IMG:style_emoticons/default/bye1.gif) (GO CHARGER'S) |
Lo-Fi Version | Time is now: 4th June 2024 - 10:33 PM |
