> Engine Compartment Fuse/Relay Help!
914Bryan
post Sep 17 2011, 03:23 PM
74 914 2.0
Pictured is the relay board in the engine compartment on the drivers side. The pencil is pointing to a blue 25a fuse. That location is towards the back of the vehicle. The open slot next to it has no fuse. What does that operate and what amp fuse belongs there? I dont want to throw a 25a in if that is wrong. HELP,HELP,HELP!!
Also, I am having problems with the drivers side running lights, front and rear are not operational and there is a huge voltage drop when I apply the breaks; goes from 13 to 10. Same thing applies when I turn on the lights. Break lights work and turn indicators work. Im thinking this is all related...Any ideas??
Attached Image (IMG:style_emoticons/default/WTF.gif)
Replies(1 - 10)
Dr. Roger
post Sep 17 2011, 04:07 PM
A bat out of hell.
Fuel pump.
See here:
http://www.bowlsby.net/914/Classic/zTN_Man06.pdf
swl
post Sep 17 2011, 04:21 PM
The empty fuse slot is not used on the later cars. Don't put anything in it.
The dimming lights could indicate bad grounds/connectors but to be affected that much by your brake lights is a little concerning. Going to take some serious troubleshooting to figure that one out.
Cap'n Krusty
post Sep 17 2011, 05:36 PM
Cap'n Krusty
Measure the voltage at the battery, not the "eye candy" voltmeter.
The Cap'n
post Sep 17 2011, 06:14 PM
Resident German
Get yourself a Haynes manual. It has wiring diagrams in it.
Or, go here:
http://www.pelicanparts.com/914/914_electrical_diagrams.htm
Tom
post Sep 17 2011, 06:27 PM
The front fuse on the relay panel is for the Sportamatic. Not used on other models of the 914. Just a convenient place for a spare fuse. Unless you have a rear window defroster, you really don't need a 25 amp fuse in the rear location. I use an 8 amp as I have no heater blower and it is just fine. A 16 amp would be a back-up if you have that fuse blowing with an 8 and you have the heater blower hooked up and operational.
The AAR is powered with the power thru that fuse and the wire for the AAR can only handle about 10 amps without burning. Several cars have had the AAR short out and damage the wiring harness between the relay board 12 pin connector and the AAR. So the wire for the AAR is "protected" by a fuse that will allow the wire to melt before blowing that 25 amp fuse.
As mentioned before, if you have a large voltage drop when applying the brakes, you have some bad connections somewhere and you need to find and correct them. Where the bulbs go for the brake lights would be a good place to look for corrosion, which can cause extra load for the brake light circuit.
Tom
dlestep
post Sep 17 2011, 07:02 PM
I am smilin'...
define AAR
Tom
post Sep 17 2011, 07:21 PM
Aux Air Regulator. Current is about 1.2 amps.
Tom
Dave_Darling
914 Idiot
Auxiliary Air Regulator. Lets more air into the manifold when the engine is cold, keeping the idle from sagging too low.
--DD
914Bryan
post Oct 9 2011, 07:00 PM
QUOTE(Cap'n Krusty @ Sep 17 2011, 04:36 PM) *
The Cap'n
Thanks Krust. Checked the voltage at the battery as you suggested, and it was at 13.8v. Even with the lights on and brakes applied, never changed. Good advice and thank you.
Now, whats up with the gauge? Replace it? Or is there an issue that it sees somewhere down the electrical line that may be a problem?
Tom
post Oct 10 2011, 08:07 AM
Your voltmeter is OK. It is reading the voltage drop on the wire coming ffrom the battery. Not the correct way to monitor battery voltage, just the cheapest for the factory. Correct way would be to run a wire from the battery to the voltmeter only.
Ever been in the shower when someone flushed and get burned by the water? Same principal.
Tom
- Lo-Fi Version Time is now: 1st May 2026 - 07:11 PM
