944 Hubs will they fit 914/4 ?, Is 944 hubs just bolt on ?? |
Niklas |
Sep 24 2011, 08:46 AM
Porsche 914 Sweden Group: Members Posts: 366 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia |
Hello!
Will 944 hubs fit directly on 914/4 ? Front and rear ? Example 477 501 605 will they fit with no modification ? |
matthepcat |
Sep 24 2011, 11:16 AM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I know that the rears will change your offset out further making your brake rotor to caliper alignment off. The rears do work in the rear bearings, as long as you use 86' or newer 944 hubs. (you will need a 5pm spacer ring to put on the 944 stub axle)
This is all assuming you are using 100mm cv's and machining your 914 axles to fit the larger cv's. (IMG:style_emoticons/default/smile.gif) So NO. Not bolt on. |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:56 AM |
