Rear Valance, Fibreglass Help |
7TPorsh |
Sep 29 2011, 10:20 AM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I have a fiberglass rear valance from Performance parts which worked ok for awhile but I started to mess with it and f'd it up.
There are 4 mounting hole tabs along the top edge. I was required to drill out the holes which i did. Problem is now the upper tab parts of the holes have broken off. Not home to take a pic but i tried to draw a good one and mine below it. Now there are no holes and no space to drill new ones. Does this make sense or do I need to post a picture? |
Dave_Darling |
Sep 29 2011, 11:10 AM
Post a picture.
However, if there is no tab to drill a hole in, you may need to build a new one with fiberglass. --DD |
rfuerst911sc |
Sep 29 2011, 11:45 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
You can take a flat metal washer and JB weld into place. Then do some glass touch up and you'll be good to go. The washer will add strength .
7TPorsh |
Sep 29 2011, 03:55 PM
JB Weld works on fiberglass?
That's an idea. |
76-914 |
Sep 29 2011, 04:23 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) Relax. It's fiberglass. You can't F*&@#% anything up. Just grind it down and add glass/epoxy and sand, file, drill or whatever.
Van914 |
Sep 30 2011, 08:19 AM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
I agree JB Weld. Used to have to redo my front air dam at lease once a year with fender washers and JB Weld.
Van914 |
7TPorsh |
Oct 10 2011, 11:32 AM
RON S. |
Oct 10 2011, 06:18 PM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
All of those solutions will work, but I must call attention to why the ears break off in the first place. The most common reason is that the fiberglass has a crappy fit in the first place. If you take the valence straight out of the box and bolt it up, you'll probably notice that not much of the valence fits tight up against the body of the car. Then you ratchet down on the mounting bolts which begins to stress the mounting tabs. Add in the day to day bumps and pot holes of normal driving, and the ears begin to break off. I noticed this with mine when it was new. It looked like a 914 valence, but when fitted, it just didn't follow the rear curve of the car at all. I took a hacksaw, and made a half a dozen or so vertical cuts across the back of my valence, until it was flexible enough to bolt to the car easily with no stress. Then with no muffler on the car I glassed it up from the back side to put the strength back in, and then cleaned up the front side. A coat of paint later I was done. 5 years on the valence is stress and crack free. It's the only way to do it with the low quality of fiberglass products one gets anymore. Not saying it happens always, but with every piece of fiberglass I ever bought for my car, serious rework had to be done 1st before it was usable on my car. Just my 2 cents worth. Ron |
7TPorsh |
Oct 11 2011, 09:19 AM
I agree the fg parts are not made well. I would love to have a steel one but too $$$.
This is from Performance Products...and yes it doesn't match well and doesn't seem long enough. Are the valances supposed to wrap all the way to the wheel opening...mine is about an inch short on both sides. |
mark21742 |
Oct 11 2011, 11:06 AM
Member Group: Members Posts: 162 Joined: 31-August 11 From: pa Member No.: 13,502 Region Association: North East States |
I like to make a large, long sheetmetal price to "clamp" fiberglass panels together instead of just bolting fiberglass to fiberglass, or fiberglass to metal......I always hated these tabs on kits......I've done several fiberglass body kits on cars for people and found that is the best way to get them to hold up.....I've also only ever installed one bumper that truly just bolted right up, all the other parts ice done needed fitting, adjusting and more glass work.
Don't get me wrong, I love fiberglass, but it can take some work to get them fitting right and to last the punishment of time on a car |
Lo-Fi Version | Time is now: 4th June 2024 - 04:13 PM |
