yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,456 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
So as many of you know my 2056cc motor is getting an overhaul due to an oiling issue. I was originally thinking that I would:
* modify my tuna can to give it more volume * finish my conversion to a single large vent at the chimney * run a 30mm pump (vs. 26mm) * baffle the case the way FAT does * move my cooler to the front bumper It's starting to seem like I would be spending close to the same amount as going the CB Performance dry sump direction. Think this is overkill for a 2056cc track/autocross car? I'm guessing it would cost me $600 total to relocate the cooler and go dry sump. |
thelogo |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None ![]() |
So as many of you know my 2056cc motor is getting an overhaul due to an oiling issue. I was originally thinking that I would: * modify my tuna can to give it more volume * finish my conversion to a single large vent at the chimney * run a 30mm pump (vs. 26mm) * baffle the case the way FAT does * move my cooler to the front bumper It's starting to seem like I would be spending close to the same amount as going the CB Performance dry sump direction. Think this is overkill for a 2056cc track/autocross car? I'm guessing it would cost me $600 total to relocate the cooler and go dry sump. well i' not a aircooled specialist but I don't think there is such a thing as overkill when it comes to keeping a oil / aircooled engine temp regulated but it sounds like you already know that from your current oiling issues (IMG:style_emoticons/default/shades.gif) then again I urge all fellow teeners to do the mod's that require the least radical changes i.e dry sump , but thats just the purist in me |
Lo-Fi Version | Time is now: 31st July 2025 - 02:25 PM |
