| machina |
Jul 30 2004, 09:05 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
Didn't even know this thing existed til jake told me about it. OEM part for vanagon blower housing. Keeps bigger stuff out of your fan and therefore off the cooling fins of your cylinders.
Bolts right on (IMG:style_emoticons/default/clap56.gif) I was going to fabricate one but now don't have to. dr Attached image(s)
| Jeroen |
Jul 30 2004, 09:12 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Ok, so stop teasing and spill yer guts...
Where did you find it? Others might be interested too cheers, Jeroen |
| rhodyguy |
Jul 30 2004, 09:18 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i've seen a lot of t-4 bus' with those. i felt they would be redundant on a 914, how much lose crap do you have in your engine compartment?. good for a rear orientated engine with the fan facing you. your tie could get sucked in. it would be a pain to remove in a 914 when you wanted to check the belt tension.
kevin |
| machina |
Jul 30 2004, 09:19 AM
Well I'm one of the few of the misguided who is not running any sealing tin on my motor, that's why I was more concerned about stuff getting in the fan from under the car.
Found it at The Bus Depot online for $8. busdepot.com, part# 021-119-207. |
| machina |
Jul 30 2004, 09:20 AM
QUOTE(rhodyguy @ Jul 30 2004, 11:18 AM) would be a pain to remove in a 914 when you wanted to check the belt tension. I don't run an alternator, so no belt. dr |
| rhodyguy |
Jul 30 2004, 09:29 AM
Lo-Fi Version | Time is now: 9th December 2025 - 04:29 AM |
