akellym |
Eyes Of The Deep Battle ![]() ![]() ![]() Group: Members Posts: 598 Joined: 25-July 04 From: Annandale, MN Member No.: 2,395 Region Association: Northstar Region ![]() |
I am looking for a good diagram of the vacuum routing for a 73 1.7. All the ones I have found are not the best. I need to know where the two lines go for the vacuum advance one the throttle body.
qa1142 |
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 ![]() |
try this. Keep in mind every car may not have every hose. EGR no EGR etc.
http://www.pelicanparts.com/914/technical_...el_diagrams.htm |
qa1142 |
I have a '74 1.8L.
The second hose from vacuum advance (actually a vacuum retard) is not there on mine. The throttle body is not even drilled for it. |
wilchek |
Senior Member ![]() ![]() ![]() Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 ![]() |
If u still need it let me know, I have a 73 1.7 that I can take a pic of.
Dan |
akellym |
the pelican part diagram does not show enough detail.
mike_the_man |
I like stuff! ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 ![]() |
What exactly do you need to know? On mine, which is a 74 2.0L, the advance hose is not hooked up, only the retard. I'm not sure if 73s have the advance port.
Now, the retard port is on the back of the throttle body, pointing towards the back of the trunk. It hooks up to the dizzy canister port that points towards the dizzy and battery. If there is another port on your throttle body, it hooks up to the port on the dizz that points away from the dizzy. If there is no port, just leave the advance port open to the atmosphere. Here is a pic that will hopefully help. Attached image(s) ![]() |
akellym |
I have the retard and the advance, there is hook up by the idle and one 180* the other side of the idle.
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
The vacuum advance port is above the throttle plate and the retard is below the throttle plate. Actually, the hose are two sizes so look carefully at them.
Geoff |
phantom914 |
non-914-owner non-club member ![]() ![]() ![]() Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 ![]() ![]() |
QUOTE(Bleyseng @ Jul 31 2004, 06:01 PM) The vacuum advance port is above the throttle plate and the retard is below the throttle plate. Actually, the hose are two sizes so look carefully at them. Geoff OK. I just need a little clarification. Is the retard port on the TB below the throttle plate when the throttle is closed and above it when the throttle is open? And is the advance port above the throttle plate when the throttle is closed and below it when the throttle is open? And what do you guys make of this: my '74 2.0, which I have had a month and I am still checking out, has both the retard and advance connected to a tee that connects to the port on the rear of the throttle body (IMG:style_emoticons/default/blink.gif) Sounds like some mechanic made a mistake. Maybe he saw the advance port on the distributor with nothing connected to it and "fixed" it? Andrew This post has been edited by phantom914: Aug 1 2004, 12:24 AM |
Lo-Fi Version | Time is now: 7th July 2025 - 12:08 AM |
