| GaroldShaffer |
Oct 26 2011, 07:15 PM
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,643 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None
This past weekend I picked up some Porsche parts and this was in the mix. Looks like maybe it is used as part of a throttle linkage for a carb setup? (IMG:style_emoticons/default/confused24.gif)
| URY914 |
Oct 26 2011, 08:08 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 131,648 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
That's looks about right.
| moparrob |
Oct 26 2011, 08:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
It attaches to early 911 carbs via brackets, like these:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1319681391.1.jpg) |
| GaroldShaffer |
Oct 26 2011, 08:37 PM
Thanks for the info. Is there any value to it? Not looking to make big$$. but if it is worth more than scrap price then I will post in the classifieds of the 911 forums.
| carr914 |
Oct 26 2011, 08:42 PM
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 131,631 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Something about it just doesn't look right to me.
They aren't worth much, I probably have 5 of the Correct ones |
| jmill |
Oct 26 2011, 08:51 PM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
| carr914 |
Oct 26 2011, 09:00 PM
I have a bunch of the Bars, but I don't have the entire kits.
I'm also a believer in using new ones - the Bushings & balls were out over time and you chase Carb problems when it really is the linkage |
| JMKnight |
Nov 21 2011, 09:34 AM
Aces & Eights ![]() ![]() Group: Members Posts: 135 Joined: 30-December 09 From: Northern Indiana Member No.: 11,188 Region Association: Upper MidWest |
I have a bunch of the Bars, but I don't have the entire kits. I'm also a believer in using new ones - the Bushings & balls were out over time and you chase Carb problems when it really is the linkage I think that it is a rear swaybar for a RollFast coaster wagon! (IMG:style_emoticons/default/lol-2.gif) |
| rgalla9146 |
Nov 21 2011, 09:47 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,943 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
This past weekend I picked up some Porsche parts and this was in the mix. Looks like maybe it is used as part of a throttle linkage for a carb setup? (IMG:style_emoticons/default/confused24.gif) 356 carb linkage |
| Socalandy |
Nov 21 2011, 09:56 AM
Its got to be Yellow!!! ![]() ![]() ![]() ![]() Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
From what I've seen and have the bar runs at an angle, not strait across like this bar and the ball joint arms are in diiferent possitions
my 2 Cents |
Lo-Fi Version | Time is now: 12th March 2026 - 09:39 AM |
