> Distributor O-ring, Is it an add on, or replacement
malcolm2
post Nov 4 2011, 05:23 PM
Everytime I put something on, I realize I probably have to use sealant or gasket, or o-ring. What is the deal here. I found on the exploded view drawings that the distributor needs an o-ring. The picture on AA and Pelican matches the shape and size of the one I got in my gasket kit. But how does it install? Does it replace the brown hard ring or just slide on and up?
Thanks,
Replies(1 - 3)
VaccaRabite
post Nov 4 2011, 05:26 PM
En Garde!
Replace.
The old one used to look like the new one, many moons ago.
Zach
McMark
post Nov 4 2011, 05:27 PM
914 Freak!
B is dead, old garbage. Cut it off with a razor blade and toss it.
A will stretch over the shaft and slide up. A should have a D cross section, not an O. The flat part goes against the shaft, and the rounded portion faces out.
malcolm2
post Nov 4 2011, 05:35 PM
QUOTE(McMark @ Nov 4 2011, 06:27 PM) *
Yes D x-section is a much better description. Thanks for the input, I am breaking out the blade.
- Lo-Fi Version Time is now: 7th October 2026 - 01:45 AM
