What's best- Media or acid |
guywan914 |
Aug 11 2004, 05:35 PM
Member Group: Members Posts: 221 Joined: 27-May 04 From: Columbia,CT Member No.: 2,112 |
As a newbie with car gutted, engine out, floor replaced and stiffeners added [thanks CFR and Restoration Design], now I need to think about final cleanup. After reading William Harris's plans for baking soda blasting ,that sounds like the way to go. Many have offered varing opinions and I would like to find your opinions on pros and cons of each. Help please. (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/confused24.gif)
qa1142 |
Aug 11 2004, 06:01 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Acid takes everything... Heater tubes... everything. It is also nasty and toxic.
Blasting is much more controlled and better for planet. I plan to have mine blasted. |
ChrisFoley |
Aug 12 2004, 05:39 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Acid dipping is a better choice for a full time race car IMO, but it should be done before any rust repair or reinforcements. It will also strip paint from places that are impossible to access for recoating.
With the media strip you can skip some areas or just go over them lightly. There's no need to remove all the factory base coat IMO. Also I would prefer to leave some of the body sealer in places where it is still fully intact. |
Quebecer |
Aug 12 2004, 01:09 PM
SuperDan Group: Members Posts: 100 Joined: 13-May 04 From: Lachenaie, Qc, CANADA Member No.: 2,063 |
I am in the process of disassembly as well, the outer shell is pretty good, I need to fix some structural stuff and I was going to remove the undercoat but I heard that it is difficult to remove with blasting (it bounces off). Would I be better off doing under the car with chemical paint stripper? (IMG:style_emoticons/default/blink.gif)
SirAndy |
Aug 12 2004, 01:15 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
do a search here on the board. this has been discussed in detail (with pictures) before.
i had my car blasted. liked it until i first drove it again. it's been over 1 year now and i still have sand coming out of the cracks everywhere! (IMG:style_emoticons/default/icon8.gif) i have seen a few acid-dipped tubs by now and they look & feel like brand new out of the factory. it's amazing how clean they are. yes, you need to get the heater-mufflers out of the longs first, but that also gives you the opportunity to fix & primer those from the inside. in any case, if i had to do it again, acid would be the only way to go for me ... (IMG:style_emoticons/default/wink.gif) Andy |
Phoenix-MN |
Aug 12 2004, 01:31 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
I had mine dipped, other than the "holes" that seem to appear from no-where It came back really nice. |
Mike D. |
Aug 12 2004, 01:58 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I used to work in warehouse and had huge acid tanks, we would used 3% acid for dipping. The thing is everything that came out of that acid had to rensed off with water. It was usually 5 to 10 min. before the surface rust would appear. I would imagine doing a 914 chassis would be the same, yes, no? not galvanized...
Plus do you really want to remove all the seam sealer form every weld on the car? Never done either one, so I probably don't know what I'm talking about anyway... -Mike D. |
Phoenix-MN |
Aug 12 2004, 02:16 PM
After it is acid dipped it is washed down and then dipped in a phosfate (sp?) bath that coats the metal and prevents flash rust from forming
GWN7 |
Aug 12 2004, 02:41 PM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
Phoenix-MN is there someone near you that does the dipping? & rough idea of cost?
Phoenix-MN |
Aug 12 2004, 05:23 PM
GWN7 -
It was many years ago that I did mine, it was a metal stripper in White Bear lake, MN (I'm not sure they are around anylonger). They stripped all the old paint, seamsealers, and then elecro-chemically/acid dipped the tub. The would attach an electrical wire to the tub (-) and another wire to the tank(+) and pass a controlled amout of current through the tank solution. This left it spotless of any rust and all bright and clean. I recall it was around $950.00 at the time. Paul |
Gint |
Aug 12 2004, 05:34 PM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Acid man! (IMG:style_emoticons/default/smoke.gif)
You've never seen a primerd tub look so nice as it does after acid dipping. |
GWN7 |
Thanks Paul, gives me a place to start looking...no one up here does it. White Bear isn't that far for me. (IMG:style_emoticons/default/biggrin.gif)
McMark |
Aug 12 2004, 06:07 PM
YES YOU WANT ALL THE SEAM SEALER OFF!! Where do you think all the rust is hiding? Behind the seam sealer. If you don't want rust problems, acid dip. It's more work, but it is worlds better than media stripping. I don't care what media you use.
heavydriver |
Aug 14 2004, 09:04 AM
Member Group: Members Posts: 158 Joined: 7-August 04 From: Orlando, Fl. Member No.: 2,470 |
Question for the central florida guys. Are there any facilities to dip my car in the Central Fl. area ??
watsonrx13 |
Aug 14 2004, 09:25 AM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
None that I'm aware of, but Paul or Rouser might be able to help.
anthony |
Aug 14 2004, 10:28 AM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
I'm pretty sure that stripping, dipping, and priming costs around $3K on top of any paint and body work.
If we are talking 4 cylinder cars here, I think it's still way easier to buy a really nice 4 cylinder car without rust for $5-6K and then just have it repainted to your specs. I would only do stripping and dippinng on an original six or if you were desperately attached to your 4 cylinder VIN number. |
SirAndy |
Aug 14 2004, 10:35 AM
QUOTE(anthony @ Aug 14 2004, 09:28 AM) I'm pretty sure that stripping, dipping, and priming costs around $3K on top of any paint and body work. IIRC $800 - $1000 around here for dipping and primer. you have to strip it down yourself, but you want that anyways regardless of the method used. (IMG:style_emoticons/default/wink.gif) Andy |
maf914 |
Aug 14 2004, 10:45 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Andy,
That dipped and primed chassis is a beauty. I remember the photos from the previous thread. Is the primer sprayed on or dipped? While most of us would love to have a spotless car like that, I doubt mine will ever see a tank of acid. Sure is pretty though. |
Gint |
Aug 14 2004, 11:28 AM
QUOTE IIRC $800 - $1000 around here for dipping and primer. Not quite. The dipping is at least $1k The primer afterwords is at least $1K. The price goes up from there based on varying options and how many pieces of car you bring them. I know. I paid the bill. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:21 PM |
