> Back Pad Removal, Push up or pull down
JawjaPorsche
post Dec 2 2011, 08:20 AM
I am removing my back pad to have it recovered.
After removing screws and hood release cap, do I pull down or push up to remove?
Thank you in advance.
Replies(1 - 4)
EdwardBlume
post Dec 2 2011, 08:25 AM
Pull the lower pad outwards after removing the four screws. The pad will be pressed DOWN to release the inner hooks on the upper part of the pad behind each seat.
Mostly, the lower pad gets hung up from below.
Don't rip the upper pad out.
Good luck.
JawjaPorsche
post Dec 2 2011, 08:33 AM
Thank you so much for the instructions and help.
Y'all are the best!
Terry
QUOTE(RobW @ Dec 2 2011, 09:25 AM) *
Good luck.
sean_v8_914
post Dec 2 2011, 08:49 AM
Chingon 601
don't forget to remove the engine lid release grommet. it has t spanner holes to unscrew it
PS. thanks for the spell check Andy
Dave_Darling
post Dec 2 2011, 06:45 PM
914 Idiot
I usually use needle-nose pliers or snap-ring pliers to unscrew the grommet. (And the other ones on the car for that matter.)
The bottom of the back pad slides forward, toward the front of the car. That gives you enough slack to push the pad downward, un-hooking the tabs on the back side of the pad from the brackets on the firewall.
--DD
- Lo-Fi Version Time is now: 31st July 2025 - 08:15 AM
