Air injection, refurbishing |
914work |
Dec 4 2011, 05:53 PM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
Anyone have any experience with cleaning the carbon buildup that plugs the "spider" pipe?
How the heck (IMG:style_emoticons/default/headbang.gif) |
PancakePorsche |
Dec 4 2011, 08:33 PM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
Kind of a pain in the butt. I heated it up good with propane torch and tapped it all over with large screwdriver until you see the carbon fall out. Use lots of compressed air back and forth to help it out. Do spray lots of carb cleaner as well. I also drilled out injection nozzles (totally clogged)and bead blasted them. Be sure to used anti-seize compound on all the threaded connections when re-connecting it all. Factory recommends cleaning the system every 30K miles. Hope this helps.
Lo-Fi Version | Time is now: 8th June 2024 - 08:23 AM |
