stripped nuts |
stripped nuts |
ruddyboys |
Aug 18 2004, 05:58 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
I am putting back on my rocker arms and I keep stripping the threads out of the nuts that go on the studs. I can see if it was one stud doing the damage but its not. I got the new nuts from my FLAPS so I hope they are strong enough? I torque them to 10lbs as to Haynes. I have 7 in place and torqued, and still have to run out and buy more nuts, stripped 4!
rhcb914 |
Aug 18 2004, 06:15 AM
member Group: Members Posts: 358 Joined: 3-February 04 From: Boston, MA Member No.: 1,626 |
Did you have the heads bead blasted? I have had this problem before, but I pulled the studs and the blasting resideu got into the holes. When I went to put the studs back in the aluminum threads stripped out. Try running a die over the studs to clean up any burrs.
ruddyboys |
Aug 18 2004, 06:28 AM
I haven't had them bead blasted, but I will try running a die over them, now to find my metric tap and die set.
JWest |
Aug 18 2004, 06:35 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Rotate the engine to relieve the valve spring pressure for the cylinder you are working on. This allows the nut to grab more threads before it sees a load.
Tom Perso |
Aug 18 2004, 06:49 AM
Crazy from the Cold... Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
Or, you could get rid of the stupid 7x1.00 threaded studs and get a real set from FAT... They use a 8x1.25 thread and I used T1 head bolts and wavvy washers to hold mine down. They are cheap and easy to put in.
(IMG:http://www.qtm.net/~persoj/graphics/vw/rocker_studs.jpg) Later, Tom |
Aaron Cox |
Aug 18 2004, 09:17 AM
yeah... i broke 2 rocker studs (IMG:style_emoticons/default/rolleyes.gif) ...
Lo-Fi Version | Time is now: 10th June 2024 - 06:40 PM |
