4 Cyl. Header |
4 Cyl. Header |
aveale |
Aug 18 2004, 11:03 AM
Fun Times Group: Members Posts: 194 Joined: 18-August 04 From: Ottawa, Canada Member No.: 2,563 |
Hello,
Cracked Heat Exchanger. Broken Heart. Anyone have info on a replacement set of Headers (I only drive in the summer) or where to locate new Exchangers? i.e. success rate, vendors, installation difficulty. Thanx Tony |
larryp |
Aug 18 2004, 11:08 AM
Member Group: Members Posts: 311 Joined: 9-May 03 From: Greenwich CT Member No.: 675 |
Headers? Sure, try Chris http://www.tangerineracing.com/
machina |
Aug 18 2004, 11:38 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
These pics are from a thread a while back...
dr Attached thumbnail(s) |
Aaron Cox |
Aug 18 2004, 11:44 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
second to last pic: are those for a 912E? seems like you could use those and then dual inline delta flow flowmasters...and dual exhausts (IMG:style_emoticons/default/idea.gif)
thesey914 |
Aug 18 2004, 11:49 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
The last pic has the headers siamesed like on a subaru?
nebreitling |
Aug 18 2004, 11:59 AM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
I run the Euro Race headers (looks like the triad above -- are they the same?). i like em. stub tubes for easy installation. $600+ new.
n |
Mueller |
Aug 18 2004, 12:01 PM
also, don't forget to check out the vendors forum here on the BBS, there is also European Racing Headers available
you really need to decide, do you want headers or heat exchangers? for heat exhangers that are a direct bolt-on, your options are: used or new stainless steel units (sold by the normal suspects, I believe HPH has them in stock right now) for headers, they are a bolt-on item as well (the best units use the seperate stub pipes such as the Tangerine and Eurorace and Triad.)....make sure you get the correct muffler since the factory unit will not work.... prices: $50 to $300+ for the heat exhangers $400 to $1200+ for the headers |
machina |
Aug 18 2004, 12:04 PM
I bought my setup directly from david at triad. He indicated that he made the headers there at his shop but who knows, maybe they are really eurorace.
dr |
914werke |
Aug 18 2004, 12:23 PM
"I got blisters on me fingers" Group: Members Posts: 10,141 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
It seems to me that at least one of these designs would lend itself to a secondary version...With Heat.
Taking thier headers and developing some mild steel wraps with inlet and oulets like the OE exchangers. If Dave H. can "garage" something together I imagine these guys with thier Manufactureing abilities it should be a breeze? I willing to bet MY $'s the market for those would be crazy (IMG:style_emoticons/default/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 06:43 AM |
