| Eddie914 |
Dec 31 2011, 08:02 PM
Unregistered |
I am doing a custom install of Wilwood Dynalite II calipers and 309mm x 32mm rotors.
How much space (radial) is needed between the caliper and the rotor? Thanks Eddie |
| SLITS |
Jan 1 2012, 08:16 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
As long as the rotor does not hit the hat (body) of the caliper you should be good to go.
| jaxdream |
Jan 1 2012, 08:44 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Also check your wheel clearence .
Jack |
| Eric_Shea |
Jan 1 2012, 02:30 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Porsche seems to use roughly 2mm as the rule. When the rotor heats up it can and will expand. We had a member here years back that had this issue. He was in Europe and after he got going a bit, he had a grinding that just got worse the longer he drove the car. Turns out his rotor was a 6 rear rotor on a 4 and as he drove and warmed it up it began to rub, as it rubbed it heated up more until it finally ground him to a halt.
Lo-Fi Version | Time is now: 8th December 2025 - 08:13 PM |
