.255 cam stock fuel inj. |
CG-914 |
Jan 20 2012, 04:36 PM
Member Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
Hi everyone.
I have a 74 2.0 with the stock fuel inj. A year ago I used to work as a mechanic in a shop for european cars. After I quit my former (IMG:style_emoticons/default/ar15.gif) boss charged me for my engine rebuild. Now the car is still not running and I give him the best of help. I built in a .255 cam from WebbCam for stock fuel inj. I know about the problems with interfering with the stock set up. But I would like to hear, if anybody built that cam in its car, and got it to work with the stock fuel inj. Thank you very much! |
nathansnathan |
Jan 20 2012, 05:31 PM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
That cam is listed as being for a hydraulic lifter engine with FI.
A hydraulic cam has a reduced base circle to give the lifters time to pressurize. I'm not sure if that is in addition to the lift? or if it is a shorter lobe with a shorter base circle for the same lift spec. I have heard, though, that running mechanical lifters on a hydraulic cam will flatten the lobes in short order. No personal experience though, sorry. |
Valy |
Jan 20 2012, 06:58 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
The lobe angle is more acute for the hydraulic profile. Use it with the hydraulic lifters and you'll be OK.
CG-914 |
Jan 20 2012, 07:13 PM
I ran it with the hydraulic lifters, that didnt work well.
I have the feeling, they dont know how to set it up! |
CG-914 |
Jan 20 2012, 07:40 PM
the car runs,
but too rich and the plugs faul after 20 minutes. there are a couple other problems with valves and injectors. the question is: Will the car run after all other problems have been solved, or will the cam continue distroing thing? Also is here somebody who build that cam in his car? |
JeffBowlsby |
Jan 20 2012, 09:41 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Call Don Ramsay at Aircooled Classics in Knoxville, tell him you were referred from 914world.com. He hangs out here now and then and knows 914s extremely well and may be able to answer your questions.
http://en.myeurosport.com/cgi-bin/welcome.pl |
JeffBowlsby |
Jan 20 2012, 09:43 PM
http://bmwrepairknoxville.myeurosport.com/...md/M10004/s3.pl |
Jake Raby |
Jan 20 2012, 09:44 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
This cam has profile characteristics that are designed especially for hydraulic lifters. Did you employ hydraulic lifters of solid lifters with it?
Stock EFI HATES hydraulic lifters, especially D jet. |
Hammy |
Jan 21 2012, 12:44 AM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
I do not like hydro lifters (IMG:style_emoticons/default/smoke.gif)
brant |
Jan 21 2012, 08:12 AM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
but for the original poster sake:
the cam and the lifters are matched (wear in as matched sets) you can't change lifters without splitting the case and changing the cam. |
Bleyseng |
Jan 21 2012, 10:45 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Djet doesn't like hydro lifters so switch to a Ljet setup and you'll be fine.
Lo-Fi Version | Time is now: 8th June 2024 - 01:01 AM |
