campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,623 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
So far I am not cooking the brakes enough to really need the duct setup, on these non brake-intensive local tracks. But sooner or later it will happen.
I like the Smart-Racing setup to hold the hoses to the a-arms. Very slick. But, their kit does not (apparently) include the key little part, that attaches the ducting to the hub/rotor assembly. On the other hand, the kits from Perf Prods and OG Racing etc that do include the little manifold thingie also come with scoops, and ducting, that I do not need because I would run the ducts up to my front spoiler/dam. Anybody have tips on how to set this up and where to get the plastic piece that directs the air into the rotor? Oh yeah, yes, I have vented rotors. 911SC "A" calipers up front and 914-4 front calipers in back, with a "tee" and 19mm M/C. Pagid pads and ATE fluid currently, although that might change. Thx, |
KenH |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 ![]() |
Call AJ-USA @ (800) 877-1911, they sell the entire kit or the parts by themselves.
Ken |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
That is who I used to get them from Chris. I couldnt remember earlier. We use the scoop style that attaches to the A arm.
B |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,954 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I use the scoop style too... got mine and got a few replacement parts also from AJ....
I know I've bought parts separate before... also I don't think the kit includes the block off plate that goes in the hub... Purpose: to block off and thus reverse the natural flow of air... I bought mine for something like 40 bucks... then found out that I had to completely refit and cut down to make them fit.. If I had it to do over I certainly would not buy them... just make a simple pattern from cardboard and cut out a pair from thin al stock.... brant |
campbellcj |
Yeah, Smart-Racing has the block-off plates ($50-ish/pair I think).
Thanks for the tip re. AJUSA. I have bought stuff from there before and will give 'em a ring. Clarification -- any reason to use the "scoops" if my front dam/spoiler has built in cooling duct inlets? Seems like I would get pretty good flow thru the spoiler. |
Brad Roberts |
Use your spoiler. Some of my guy's like to run that chin spoiler that acts like a difuser. Sooo they run the small scoops attached to the control arms.
B |
Lo-Fi Version | Time is now: 13th May 2025 - 03:22 AM |
