| Bruce Hinds |
Jan 27 2012, 03:50 PM
V-8 madness ![]() ![]() ![]() Group: Members Posts: 763 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
Has anyone use the boxter tranny in a teener? I'm wondering too about the gears and strength for a V8 application.
| DBCooper |
Jan 27 2012, 04:27 PM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
The expert: http://www.914world.com/bbs2/index.php?sho...=109434&hl=
Just leave out the Subaru parts. |
| Dave_Darling |
Jan 27 2012, 04:35 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,342 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
It's been done; there is a member on the Pelican 914 BBS who had a shop transplant a Boxster trans onto the 3.2 in his 914. He said it cost more than the original conversion, but that it shifted very well.
--DD |
| Rand |
Jan 27 2012, 04:38 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,415 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Seems like there was a very nice red 914 with a Boxster tranny.... I remember pics from a few years ago on here. Maybe the same one DD is referring to.
I think his screen name was ABC914. Time for a search... |
| Rand |
Jan 27 2012, 04:43 PM
I found a couple pics of the red car. Gotta be a thread somewhere.
| SUNAB914 |
Jan 27 2012, 04:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
That car is goergeous, hell I can't even spell it right now!
| a914622 |
Jan 27 2012, 07:15 PM
Member ![]() ![]() Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest |
I know it can be done BUT, For a V8 I would put a subaru (2010-2012) Diesel 6 speed in. Good low rpms and new they are only 3600.00. Plus the diesel suby cluch is rated at 350 flb stock on a push style.
Not sure of the boxster. But then again there is the tdi audi from euro that would have the lower gearing and look just like the boxster?? Just saying.. Jcl |
| Bruce Hinds |
Jan 27 2012, 10:36 PM
I know it can be done BUT, For a V8 I would put a subaru (2010-2012) Diesel 6 speed in. Good low rpms and new they are only 3600.00. Plus the diesel suby cluch is rated at 350 flb stock on a push style. Not sure of the boxster. But then again there is the tdi audi from euro that would have the lower gearing and look just like the boxster?? Just saying.. Jcl Higher gearing and wider gear sets are what's needed for a v8 |
| a914622 |
Jan 27 2012, 10:54 PM
I know it can be done BUT, For a V8 I would put a subaru (2010-2012) Diesel 6 speed in. Good low rpms and new they are only 3600.00. Plus the diesel suby cluch is rated at 350 flb stock on a push style. Not sure of the boxster. But then again there is the tdi audi from euro that would have the lower gearing and look just like the boxster?? Just saying.. Jcl Higher gearing and wider gear sets are what's needed for a v8 Higher gearing ? Meaning higher rpms? I know there are audi v6 diesels putting 450 flb to the ground tuned. Lots of tork to push thru a tranny. Youd have to have a 500 hp gasser to get that kind of tork. What hp are the boxters putting out? I remember seeing an artical about the boxter trannys using a sealed bearing that was failing at 20k miles. The fix was a rebuild and unseal it so the tranny oil could lub the bearings. |
| Jake Raby |
Jan 28 2012, 09:07 AM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
I've got a spare Boxster S 6 speed...
Stock Boxster engines make a max of 230RWHP unless the car is a 2006 or newer. The Boxster S engine from the factory its rated at 250P, on my chassis dyno we see 220-230RWHP from these on a routine basis. But we have reconstructed Boxter engines to make 300RWHP without issue. If you want the tranny just let me know. 2K takes it, 43,000 miles. |
| Steve |
Jan 28 2012, 09:15 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,047 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Who makes the tranny mounts for the Subaru or Boxster trans that fits the 914?
| rohar |
Jan 28 2012, 09:29 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 924 Joined: 25-October 08 From: spokane Member No.: 9,685 Region Association: None |
I just made my first tranny mount for the Boxster/Audi tranny. Walk in the park if you've got a welder.
Anyone know what starter precisionchassis used in the link DBCooper provided? While I was on the Left side of the state, this week, I picked up a couple of bags of refractory for the new foundry. Casting bellhousings is a possibility by spring. (IMG:style_emoticons/default/biggrin.gif) Oh, and for you V8 guys, there are some REALLY tall Audi trannies out there that are virtually identical to the boxster tranny. |
| Cap'n Krusty |
Jan 28 2012, 10:18 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
I know it can be done BUT, For a V8 I would put a subaru (2010-2012) Diesel 6 speed in. Good low rpms and new they are only 3600.00. Plus the diesel suby cluch is rated at 350 flb stock on a push style. Not sure of the boxster. But then again there is the tdi audi from euro that would have the lower gearing and look just like the boxster?? Just saying.. Jcl Higher gearing and wider gear sets are what's needed for a v8 Higher gearing ? Meaning higher rpms? I know there are audi v6 diesels putting 450 flb to the ground tuned. Lots of tork to push thru a tranny. Youd have to have a 500 hp gasser to get that kind of tork. What hp are the boxters putting out? I remember seeing an artical about the boxter trannys using a sealed bearing that was failing at 20k miles. The fix was a rebuild and unseal it so the tranny oil could lub the bearings. "Higher" gearing means more MPH with fewer RPMs, not the other way around. The Cap'n |
| Dr Evil |
Jan 28 2012, 11:27 AM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,044 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Diesel box with taller gearing would be ideal for a V8. I agree. Where do we find these?
| rohar |
Jan 28 2012, 12:02 PM
Diesel box with taller gearing would be ideal for a V8. I agree. Where do we find these? The Audi 01x from the European only A6 TDI FWD is the go to. It's virtually indestructible. The kit car guys love it. There's a guy in texas that imported a bunch of them and sells them. I think he wanted over $2k each. The second option is the 012 code WW0 tranny. It was initially designed for a FWD audi diesel in the mid '90s but was later used on FWD audi 12v V6s in the states. There's a bunch of them available cheep (I bought mine for $300 with a perfectly good engine attached to it) and will take you to 150mph at 6000rpm. |
| precisionchassis |
Jan 28 2012, 02:41 PM
Member ![]() ![]() Group: Members Posts: 99 Joined: 26-July 10 From: Gilbert, AZ Member No.: 11,979 Region Association: Southwest Region |
There are a few companies that make adapter kits (including Kennedy) to mate an LS motor to the 996/986 S transaxle. Both transaxles are basically the same with the exception of mid/rear engine configurations. Ultima uses the 996 version in their kit cars and invert it for mid-engine use with better CV/axle geometry.
Both transaxles use G50 differentials and G50 style parts, but the main shaft/gears are an interference fit rather than splined which could be the limiting factor in the horsepower department. I'll be pumping 400whp through the Boxster version (G86/20) and 360ft/lb with the Subaru engine. I'll find out exactly where the limit is soon enough I'm sure. |
Lo-Fi Version | Time is now: 9th June 2026 - 08:59 AM |
