Shift coupler bushing, how to install? |
jr91472 |
Sep 1 2004, 03:06 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
This is the shift coupler for my new side shifter shift linkage. My new bushings for this coupler are in the mail. To install the bushings, am I supposed to drive this pin out to disassemble?
Any secrets that someone want to share? Thought I would ask before I start banging (IMG:style_emoticons/default/headbang.gif) Attached image(s) |
Joe Ricard |
Sep 1 2004, 03:15 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Yes just keep hitting with MFH (thats medium hammer) and a punch maybe 1/4" end. should just slide right out. (IMG:style_emoticons/default/smash.gif) Just be carefull not to bugger up the ends. If you do then they can be cleaned up with a file before you put the pin back in.
Porsche Rescue |
Sep 1 2004, 04:06 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
Method I used recently: 15mm deep socket, short bolt slightly smalller than the diameter of the pin, vise; I put the head of the bolt against one jaw, joint pin in the middle and socket (hollow end toward pin) against other jaw. Use the vice as a press.
jr91472 |
Sep 1 2004, 05:09 PM
sweeet...thanks (IMG:style_emoticons/default/beer.gif)
Lo-Fi Version | Time is now: 2nd June 2024 - 07:54 AM |
