Los Angeles: 1985 PORSCHE 928S 928 928S4 911 914 924 1986 1987 1988 1989 1990 1991 (eagle rock/los angeles) $1900 |
914World |
Feb 5 2012, 01:48 AM
Member #1 Group: Members Posts: 130,681 Joined: 23-December 02 From: World Wide Web Member No.: 1 Region Association: None |
THIS WAS MY MAIN TRANSPORTATION CAR UNTIL THE THROW OUT BEARING WENT OUT. THERE IS NO CLUTCH ACTION BUT ITS EITHER IN GEAR OR NOT DEPENDING IF ITS SHIFTED SO. IT RUNS GREAT. IT HAS A SMALL OIL LEAK BUT THERE ARE A COUPLE OF OIL PAN BOLTS MISSING IN THE FRONT PASSENGER SIDE WHERE ITS APPEARANT. THE SMOG PUMP IS FROZE UP AND THE POWER STEERING IS DISCONNECTED DUE TO A SLIGHT LEAK. SO THE ALTERNATOR IS ONLY RUNNING OFF THE ENGINE. THE AC BELT IS OFF. ITS A 5 SPEED STICK SHIFT. THE CLUTCH IS SOLID CONDITION BUT THE BEARING IS NOT. IT HAS ABOUT 179K ON THE CAR.THE TIMMING BELT AND WATER PUMP IS FRESH WITH VERY LITTLE MILES. THE FRONT WINDOW NEEDS REPLACEMENT DUE TO A CRACK. THE BODY IS NOT CHERRY BUT SATISFACTORY. THE FRONT DRIVERS SIDE FENDER CAN BE REPAIRED OR REPLACED.THE SEATS I THINK ARE FROM A 911 AND ARE ELECTRIC IN POSITIONING ETC. THE RIMS ARE COOL TOO FROM A 911 WIDE BODY I BELIEVE AND THE TIRES ARE EXCELLENT. THESE ARE WORTH MOST OF MY ASKING PRICE.THE TAGS EXPIRE IN APRIL OF 2012. THIS IS A BIT OF A PROJECT BUT THE HEADACHE OF THE TIMMING BELT AND WATER PUMP ARE OUT THE WAY.FIX THE BEARING AND THE REST IS EASY. THE TIMMING BELT AND WATER PUMP IS A $2500 JOB AND I PAID $3500 FOR THE CAR SO THERES A LOT OF MONEYS WORTH INVOLVED.DESPITE OF THE WORK IT NEEDS ITS LOWBALLED IN PRICE IN COMPARISON TO THE OTHERS FOR WHAT THEY REALLY ARE. THIS IS AN IDEAL CAR FOR A MECHANIC TO FIX AND SELL FOR A PROFIT. THIS CAR IS VERY FAST AND WAS FUN TO DRIVE BUT IM A TAME DRIVER AND DONT DRIVE IT HARD MOST OF THE TIME.
Lo-Fi Version | Time is now: 11th June 2024 - 09:41 PM |
