WTB: 2, black, 5 lug, 8x16 Fuchs |
ruby914 |
Feb 9 2012, 02:45 AM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
I need of a set of black center, 5 lug, 8x16 Fuchs, 911 offset.
911.361.020.45 or 911.362.117.XX With that, I will have this set of all black 6x16 Fuchs F/S. Attached image(s) |
euro911 |
Feb 9 2012, 01:55 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
What are you up to now, Mike (IMG:style_emoticons/default/confused24.gif)
I need to stop by and see your progress ... |
mlindner |
Feb 10 2012, 10:16 AM
Senior Member Group: Members Posts: 1,528 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
ruby914 |
Feb 10 2012, 10:42 AM
What are you up to now, Mike (IMG:style_emoticons/default/confused24.gif) I need to stop by and see your progress ... Hi Mark, I got the GT flares on, 21mm spacers up front and found I need more than the 6" & 7" fuchs that I had under the rolled fenders. The 7s will go up front if I can find some good 8s. Yes, we both have to stop in on each other sometime. (IMG:style_emoticons/default/agree.gif) |
ruby914 |
Feb 10 2012, 10:46 AM
I need of a set of black center, 5 lug, 8x16 Fuchs, 911 offset. 911.361.020.45 or 911.362.117.XX With that, I will have this set of all black 6x16 Fuchs F/S. Is the front suspension for sale, hubs, brakes, struts etc. Thanks, mark No Mark, It's installed. I do have one F/S from an early 911 but it's not what you would want for a 914. |
euro911 |
Feb 10 2012, 12:41 PM
Mike, isn't an early 911 front suspension what the original 914/6 came with?
I realize that later front ends with 3.5" caliper bolt spacing are more desirable so one can install vented rotors, but wouldn't an early front suspension still be usable for a 5-lug conversion? |
ruby914 |
Feb 11 2012, 02:23 AM
Mike, isn't an early 911 front suspension what the original 914/6 came with? I realize that later front ends with 3.5" caliper bolt spacing are more desirable so one can install vented rotors, but wouldn't an early front suspension still be usable for a 5-lug conversion? Mark, The A arm and strut interface is different on the early 911 and 912s I don't think the 914-6 used this setup. Best I can tell, it fits a 64 - 67 911 or 912. It will all fit a 914 but the arms and struts would have to stay together. The A arms I have are rusted through so I made a jig to repair the arms. Later, I found a local, much newer front end with turbo tie rods and poly bronze bushings. You can see the front end here: http://forums.pelicanparts.com/porsche-911...-front-end.html |
Lo-Fi Version | Time is now: 7th June 2024 - 10:50 AM |
