San Diego: Porsche 912 / 356 Parts (bonita) $1 |
914World |
Feb 20 2012, 10:11 AM
Member #1 Group: Members Posts: 130,681 Joined: 23-December 02 From: World Wide Web Member No.: 1 Region Association: None |
I have several porsche parts in thier ORIGINAL PACKAGING!!
A German Rienz Lower gasket kit for a Porsche 356 or 912 UNOPENED #616.101.901.01 $ 30.00 ( Upper kit is sold ) Have also German Glyco Rod Bearings in STD. #616.103.142.02 $ 28.00 and also PORSCHE Boxed O.E. .010 #616.103.142.52 $40.00 Ring Set (yes all 4) for the big Bore 86P's Made in Japan #PR1465 $25.00 Several Mahne oil filters, 5.00 each Bosch spark plugs, $ 1.00 each Clutch cable $ 10.00 German 10X965 fan belt. 4.00 German Belt 10x740 $4.00 And a engine block FACE PLATE only, with no serial numbers .Takes the press in seal. SHOULD FIT 356b/356c/912 Probably fit earlier 356a $100.00 German Sachs throw out bearing #901.116.81.11 and replacement pilot bearing #111.105.313A for the gland nut, for all 914's /912's and 1966-69 2.0 911's $75.00 Also some new and some used Lug Nuts 2.00 Each And a used 912 cam shaft with no gear. 20.00 If it is still listed it is still available. I update as they sell mike 619.204.38 zero zero
View the full article THIS IS NOT A 914WORLD AD! Do not reply to this thread! No one is listening! Click on the "View the full article" link above to go to the actual Ad! |
Lo-Fi Version | Time is now: 13th June 2024 - 05:12 AM |
