Wood dash glue |
Wood dash glue |
914itis |
Feb 22 2012, 08:11 AM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
What is the best glue to attach a wooden dash?
r_towle |
Feb 22 2012, 08:33 AM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Properly prepared metal with a solid coat of paint.
You should try a small spot of contact cement to see if it peals the paint. If it does, use construction adhesive Spread it out like tile adhesive so you have notches and then squish the wood down to the adhesive so it spreads out. Rich |
TheCabinetmaker |
Feb 22 2012, 08:58 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Either will work just fine and would be my choices also. The contact will work better, it just has to be properly placed the first time. There is no second time. A waterborne contact will not peel the paint. The original formula contact, that uses lacquer thinner to clean up with, is still the best. Don't use it inside and try not breath much of it.
matthepcat |
Feb 22 2012, 10:38 AM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
My wood dash only had double sided tape to remove vibration and the rest was held on by the components in the dash.
IronHillRestorations |
Feb 22 2012, 01:03 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
If the wood is very thick, the double sided tape isn't a bad idea, as it lets the wood contract at a different rate than the steel it's fastened to.
If it's very thin veneer, then I'd go with contact cement too. |
gandalf_025 |
Feb 22 2012, 03:20 PM
Senior Member Group: Members Posts: 1,456 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
Here is a picture of the back of a Wood Dash,
as it was removed from a car in the early 70's This one was attached by double sided tape of some sort. |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:09 AM |
