Porschef |
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States ![]() ![]() |
Got about 800 miles on these, pulled em out to open the gap with the Pertronix
install. How do these look to you? All four are essentially the same. Nevermind the tea leaves. Attached thumbnail(s) ![]() Attached image(s) ![]() |
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
Looks lean or plug is too hot.
Check this thread and compare your plugs to the pictures. http://www.914world.com/bbs2/index.php?sho...481&hl=plug |
struckn |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region ![]() |
They look Good, almost perfect.
whatabout1 |
Toys in Red ![]() ![]() Group: Members Posts: 403 Joined: 6-March 06 From: Charlotte, NC Member No.: 5,676 Region Association: None ![]() |
Very lean or hot. I don't like that little chip on the ceramic in the close up pic.
So lean you may be getting knock (chip). Next you will have to worry about the exhaust valves. |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Reading plugs supposedly became inaccurate with the use of unleaded fuels.
Cap'n Krusty |
Porschef |
I'm running Ljet. I haven't read the A/F ratio. I do get some light pinging under load. And I don't know how to enrich the mixture.
What now? |
ConeDodger |
I'm running Ljet. I haven't read the A/F ratio. I do get some light pinging under load. And I don't know how to enrich the mixture. What now? You don't necessarily need to enrich the mixture. (please understand, I am not saying you are or are not running lean. You don't know, and plug reading is an obsolete black art with the advent of unleaded fuel). Light pinging under load can be taken care of with a bit of timing change. If you really want to know what your A:F ratio is, you have to check it. I would guess though, that with all things running correctly, you have a pretty good A:F ratio. Properly operating LJet is taking care of that for you without adjustment. IIRC, there is only one 'adjustment' and it is on the AFM and is only intended to adjust for idle conditions. LJet uses TPS, CHT, and Air Flow to meter fuel. People have fooled with the spring tension in the AFM, put resistors in line with the CHT, etc. to try and get more 'performance' out of their LJet engine. Instead, I think they have gotten less driveability. Adjust your valves, check your timing, then go through the procedure outlined in the Bosch manual or it might even be in the FSM to check your LJet. Make sure your wiring is in good shape as the CHT uses a resistance signal, and the AFM and TPS use a position signal. If your wiring is bad your signal to the ECU will be garbage. Frankly though, if all you have is light pinging under load you are worlds ahead of the jackstand brigade around here. (IMG:style_emoticons/default/smile.gif) |
Porschef |
Rob, thanks for the reply. The car runs good, and I may have discovered a slight vacuum leak this afternoon, I'll have to see this weekend.
The only thing that was bugging me was the idle. Joe |
ConeDodger |
Rob, thanks for the reply. The car runs good, and I may have discovered a slight vacuum leak this afternoon, I'll have to see this weekend. The only thing that was bugging me was the idle. Joe LJet (most all EFI systems) HATES vacuum leaks. Unmetered air will cause a high idle and can cause a lean condition. (IMG:style_emoticons/default/biggrin.gif) |
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
Porschef |
It would start ok and then idle way too low until warm, then be pretty good when fully warmed. Never truly consistent though.
I had to wait for it to fully cool to see if it improves with the possible vacuum leak found. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 09:42 AM |
