front trunk won't open, show me a thread to unlatch the trunk |
mepstein |
Mar 2 2012, 11:26 AM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I pulled off the bumper. what's next? thanks, mark
TheCabinetmaker |
Mar 2 2012, 11:31 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
screwdriver in the hole in the middle just below the trunk lid.
r_towle |
Mar 2 2012, 11:34 AM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
when you stick the screw driver in the hole, you are just hooking onto the end of the cable.
the cable comes from the drivers side and gets pulled towards the drivers side. Use the screw driver as a lever to move the latch as if you were pulling the cable... its very slight.....not alot of movement Push down on the lid while you do it to relieve the pressure. Rich |
914werke |
Mar 2 2012, 11:44 AM
"I got blisters on me fingers" Group: Members Posts: 10,140 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
The hole is under a small rubber plug center top on the front panel. Sometimes it is painted over & less than obvious.
mepstein |
Mar 2 2012, 12:06 PM
mepstein |
Mar 2 2012, 12:10 PM
when you stick the screw driver in the hole, you are just hooking onto the end of the cable. the cable comes from the drivers side and gets pulled towards the drivers side. Use the screw driver as a lever to move the latch as if you were pulling the cable... its very slight.....not alot of movement Push down on the lid while you do it to relieve the pressure. Rich I have a spare latch so once I knew where to look for the hole (under the paint covered plug) it was easy. Now I will lube and adjust everything. Thanks everyone! Also discovered one bolt missing out of 4 on the bumper and no dog bone rubber spacers. |
Lo-Fi Version | Time is now: 8th June 2024 - 01:16 PM |
