fuel pump problem, pulses with emergency lights |
Jesse |
Mar 4 2012, 03:53 PM
Jesse Group: Members Posts: 149 Joined: 15-February 10 From: Mobile, AL, USA Member No.: 11,363 Region Association: South East States |
so it took me a while to figure out that the pump would even work with the flashers on but anyways...
I have carbs so the pump is hooked up with SirAndys How to. When i turn on the key the pump kicks on for like a second then nothing, but if i turn on the hazard lights the pump comes on as the lights blink as in bump bump bump... i have traced wires and found no bad spots and nothing grounding out. any suggestions or help is welcome |
Jesse |
Mar 4 2012, 07:58 PM
Valy |
Mar 4 2012, 10:26 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
so it took me a while to figure out that the pump would even work with the flashers on but anyways... I have carbs so the pump is hooked up with SirAndys How to. When i turn on the key the pump kicks on for like a second then nothing, but if i turn on the hazard lights the pump comes on as the lights blink as in bump bump bump... i have traced wires and found no bad spots and nothing grounding out. any suggestions or help is welcome Trace again. |
914itis |
Mar 4 2012, 11:00 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Need more detail, Was the pump working right before? Did you just acquire this vehicle? it maybe that the po wired the pump on on of the turn signal (IMG:style_emoticons/default/av-943.gif) , if itbeas working and you did not make any changes, you have a wire short somewhere,
Where did you the power for the pump from? (IMG:style_emoticons/default/agree.gif) " trace again" |
Lo-Fi Version | Time is now: 8th June 2024 - 02:08 PM |
