Juniors_914 |
dumbass Member ![]() ![]() Group: Members Posts: 92 Joined: 30-June 04 From: Los Angeles, Ca Member No.: 2,279 ![]() |
Well to make a long story short,a week ago i started to take the whole F.I and engine tin out of the car for cleaning (engine comparment was full of leaves) then today when i finished putting everything in I tried cranking the engine, but when i turned the key, the Fuel Pump fuse burned out, I checked the connection that goes to the pump and everything looks ok. Can anyone please tell me what they think might be causing this? or what I should check for?
TIA (IMG:style_emoticons/default/unsure.gif) -Junior |
JoeSharpOld |
Does it seem cold to you ![]() ![]() Group: Members Posts: 361 Joined: 29-April 04 From: Camping in Neverland Member No.: 2,001 ![]() |
Junior: I just went through that. The fuel pump gets its signal form the computer. You need to isolate the circut that is blowing the fuse. Try pulling the relays one at a time.
Joe |
F4i |
914 DOG! ![]() ![]() Group: Benefactors Posts: 482 Joined: 22-December 03 From: AB Canada Member No.: 1,460 ![]() ![]() |
That fuse is also for the heater blower motor. Maybe it is shorted to gound somewhere when you put everything back. Take a look for that.
ablose58 |
rust never sleeps ![]() ![]() ![]() Group: Members Posts: 584 Joined: 6-December 03 From: port orchard,wa. Member No.: 1,422 ![]() |
QUOTE(F4i @ Sep 15 2004, 08:33 PM) That fuse is also for the heater blower motor. Maybe it is shorted to gound somewhere when you put everything back. Take a look for that. I agree,check all your wiring for something pinched. |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Your AAR is grounding out at the plug likely. It is the same power. AAR=canister looking thing that air is bypassed through. I'll bet that that is it (ask me how I know).
Attached image(s) ![]() |
F4i |
Good call I forgot about that one.
Juniors_914 |
Thank's you guy's for the quick reply's. I havent had any time to work on the car (IMG:style_emoticons/default/sad.gif), but as soon as i get some time I'll use your helpful advice and see where that get's me
(IMG:style_emoticons/default/smile.gif)-Junior |
Lo-Fi Version | Time is now: 3rd July 2025 - 04:41 PM |
