oil cooler seal leak |
914itis |
Mar 13 2012, 08:23 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I have a leak on my oil cooler seal, a big one. can I remove it without dropping the engine or removing the fan shroud? (IMG:style_emoticons/default/sheeplove.gif)
tod914 |
Mar 13 2012, 08:31 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Yes you can. It can be a PIA, depends upon how small your hands are. George's Tech tips from AutoAtlanta outlines it. I think Pelican Parts might also outline the procedure.
914itis |
Mar 13 2012, 08:33 PM
I have done enough practice, I dropped 4 so far, I am good! for some reason the first one was the fastest. Hey Scott, You went off the map, hopping to see you at Hershey. |
914itis |
Mar 13 2012, 08:34 PM
Yes you can. It can be a PIA, depends upon how small your hands are. George's Tech tips from AutoAtlanta outlines it. I think Pelican Parts might also outline the procedure. Thanks, I am happy to hear that. everything else is nicely set, I would be pissed to drop that engine. |
914itis |
Mar 14 2012, 10:26 AM
Either these cars are made to drive us nuts or I am seeing things.
It was leaking yesterday about 1 drop every 5 second. for the 10 minutes idle, i think I lost about 1/4 of quart. still on the floor as proof that I am not loco. This morning I decided to make sure that the oil was not dripping from my pressure switch as suggested here on most threads. There was no sign , pressure switch area is dry. I wiped the oil, started the car and let it idle for 30 minutes and rev it every now and then, there was no leak. has anyone experienced this before? |
914itis |
Mar 14 2012, 11:35 AM
I forgot to mention that the only thing I did between the change ( from leak to no leak ) was setting the dwell to 49 from 68
Valy |
Mar 14 2012, 01:58 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Did you top the oil? Maybe you lost too much.
Check that the leak is not from under the dizzy retaining bracket. |
914itis |
Mar 14 2012, 10:23 PM
Did you top the oil? Maybe you lost too much. Check that the leak is not from under the dizzy retaining bracket. hm! I think you sre right, (IMG:style_emoticons/default/sheeplove.gif) The oil level was very high, I drainned it and change. It was on my to do list for this week anyway.. |
Lo-Fi Version | Time is now: 4th June 2024 - 08:54 AM |
