Passenger side mirror, Just noticed my car doesnt have one |
davidcalvin |
Sep 21 2004, 10:14 AM
Member Group: Members Posts: 200 Joined: 31-August 04 From: California Member No.: 2,662 |
Did passenger side mirrors not come stock on the 914s?
I'd like to have one, but would hate to un-stockify.. |
SLITS |
Sep 21 2004, 10:25 AM
Oh Man, you need to look for the
ULTRA RAREpassenger side mirror. The only place I have ever seen them is on eBay. They go for $200.<_< Ok, now that I've had some fun, the answer is no. You flip a regular mirror over. There are two weld nuts on the pass door already. You need to pull the panel and use a center punch to mark where to drill from the outside. Now, wasn't that easy! |
Aaron Cox |
Sep 21 2004, 10:26 AM
there was a pass side mrror available. it had CONVEX glass in it (IMG:style_emoticons/default/wink.gif)
SLITS |
Sep 21 2004, 10:32 AM
QUOTE(acox914 @ Sep 21 2004, 09:26 AM) there was a pass side mrror available. it had concave glass in it (IMG:style_emoticons/default/wink.gif) Yeh it did, right after you went to the glass shop and asked them to put one in. And I believe freshman college boy, you would want the glass to be convex. (IMG:style_emoticons/default/blink.gif) |
SLITS |
Sep 21 2004, 10:33 AM
SLITS |
Sep 21 2004, 10:35 AM
Wow, a double post without trying - Do I win a prize?
iamchappy |
Sep 21 2004, 10:43 AM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
The tapped mounting holes are there, you can feel them inside the door, locate the holes inside the door and use a small punch to center the hole and make a light impression to show on the outer door skin then carefully drill just breaking through the metal, you can use the driver door mirror mounting holes to size the drill bit.
Any driver side mirror will work if you loosen it up and flip them around. |
SLITS |
Sep 21 2004, 10:54 AM
QUOTE(acox914 @ Sep 21 2004, 09:39 AM) QUOTE(SLITS @ Sep 21 2004, 09:32 AM) QUOTE(acox914 @ Sep 21 2004, 09:26 AM) there was a pass side mrror available. it had concave glass in it (IMG:style_emoticons/default/wink.gif) Yeh it did, right after you went to the glass shop and asked them to put one in. And I believe freshman college boy, you would want the glass to be convex. (IMG:style_emoticons/default/blink.gif) nope....concave. convex, youd see sky, and road but hardly anything behind you (IMG:style_emoticons/default/wink.gif) Well Bud, I drive a semi when our flaky drivers don't show up and the mirrors on it are Convex so you can see the idiot 4 wheeler doing really stupid things just before you run over his ass. But I guess being from Corona, concave works for you (IMG:style_emoticons/default/biggrin.gif) |
maf914 |
Sep 21 2004, 10:59 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I've installed a mirror on my car using the original mounting points. As Iamchappy said, remove the interior door panel and reach up to locate the welded nuts. Use a punch or similar tool and tap the center of each nut to mark the drill point. Then drill from the outside. First I covered the area around the holes with masking tape to prevent scratches if I had a tool slip. I was concerned about fouling the threads, so I used a small bit and gradually enlarged the holes using larger bits and then a tapered rotary file. I cleaned everything and used a rust preventative primer on the bare metal, then screwed in the new mirror with rubber gasket.
SLITS |
Sep 21 2004, 11:03 AM
QUOTE(acox914 @ Sep 21 2004, 09:56 AM) i might be wrong.... i'd like to hear it from someone else tho (IMG:style_emoticons/default/wink.gif) Right or wrong is not the germain subject - arguing over nonsense is (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/mueba.gif) |
Aaron Cox |
Sep 21 2004, 11:04 AM
phantom914 |
non-914-owner non-club member Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 |
QUOTE(acox914 @ Sep 21 2004, 08:56 AM) i might be wrong.... i'd like to hear it from someone else tho (IMG:style_emoticons/default/wink.gif) OK. Convex. Now you've heard it from someone else. (IMG:style_emoticons/default/wink.gif) Andrew |
phantom914 |
Sep 21 2004, 11:05 AM
Damn. Must learn to type faster.
Andrew |
Lo-Fi Version | Time is now: 6th June 2024 - 05:13 PM |
