Oh....the horror, tranny failure |
jr91472 |
Sep 23 2004, 03:16 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
Thought I would start a new thread for all to view and learn from.
Got the muffer and muffler bracket off for a better view. Check out the arrow below the hole?? more failure in case? Went ahead and drained the oil. Hope I don't find too much metal. Tomarrow I will start unbuckling everything so i can drop the tranny lower. Then we'll peer into the abyss..... (IMG:style_emoticons/default/sad.gif) later Attached image(s) |
rhodyguy |
Sep 23 2004, 03:25 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
YOIKS!! what a drag. three posts on the front page regarding your transmission. from (IMG:style_emoticons/default/smilie_pokal.gif) to (IMG:style_emoticons/default/ohmy.gif) to (IMG:style_emoticons/default/sad.gif) .
kevin |
SLITS |
Sep 23 2004, 03:35 PM
That looks like the vehicle in "Journey to the Center of the Earth"comin' outta der.
Hell, a little fibreglass cloth, some JB weld and 200 MPH race tape and you'll be back on the road. (IMG:style_emoticons/default/smash.gif) |
smrz914 |
Sep 23 2004, 03:42 PM
Soon to be brightening the life of the person behind you. Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
Haha that's what happened to my last transmission! Sorry i'm not laughing at you, i'm just glas i wasn't the only one. I just broke my third. The first a washer/spacer shreaded apart and fot stuck in the pinion and the second looked like yours and the third makes some really nasty sounds. Good luck with that. What are you gonna do to fix that?
Joseph Mills |
Sep 23 2004, 04:00 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
QUOTE(jr91472 @ Sep 23 2004, 03:16 PM) Thought I would start a new thread for all to view and learn from. Tomorrow I will start unbuckling everything so i can drop the tranny lower. Then we'll peer into the abyss..... (IMG:style_emoticons/default/sad.gif) You gotta good attitude. Keep after it. (IMG:style_emoticons/default/beer.gif) |
SirAndy |
Sep 23 2004, 05:23 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
you should be able to just replace the back plate.
you can do that without dropping the tranny. that is, IF the internals check out OK otherwise ... (IMG:style_emoticons/default/wink.gif) Andy |
bondo |
Sep 23 2004, 05:35 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I don't know what that is (arrow), but I don't think it's related. probably just a casting defect that the factory considered acceptable. No case/cover defect could have cause this, it was definitely a failure from the inside out.
Red-Beard |
Sep 23 2004, 11:09 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
Uh, guys, that is the speedo drive gear that _DRILLED_ its way through the rear case. Either the pinion bearing failed or the large nut at the end of the pinion shaft was not tightented, came loose and machined a hole in the case.
In either case, the rear cover is hosed. Get the rear cover from your tailshift tranny and install. Or better yet, do a sideshift conversion on your old tranny and take the best parts from the two. If the bearing is OK, you will still need to replace the big nut/worm drive. It takes a 30mm socket. James |
Red-Beard |
Sep 23 2004, 11:16 PM
See the "RED"
Attached image(s) |
jr91472 |
Sep 24 2004, 03:55 AM
James, hoped you would chime in.
It will be a couple of days before I am inside the tranny to inspect. In the meantime, are there any clues (from how the car was behaving) to describe the two failure scenerios you described? Also, regarding using the tailshifter end cover, I core swapped the whole thing so....not an option. But I will be contacting the seller to "sort this out" thx |
jr91472 |
Sep 24 2004, 05:38 AM
Not sure if this is worth noting. This pic is the bottom of my drip pan after draining the tranny last nite.
No big chucks of metal yet, but lots of brass fragments (from the bolt). At some point, I will need to learn how to do a proper flush of the tranny. Can this be done with the tranny in the car? Attached image(s) |
ClayPerrine |
Sep 24 2004, 06:48 AM
Life's been good to me so far..... Group: Admin Posts: 15,514 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If you want some help.. I have all of the tools and lots of experience with 914 transmissions. Plus I live in Hurst, so it's not that far to McKinney...
The rear cover on your transmission is hosed. But if the internal parts are good, we can put a new cover on it. Let me know if you need some help. |
jr91472 |
Sep 24 2004, 10:54 PM
Made some progress today. Got everything unbuckled and lowered the tranny to a workable level.
Rear cover is being stubborn, but was able to remove the speedo drive (see below). Looks none worse for the wear (to my untrained eyes). Important to note that with the drive removed, I can see that the 30mm bolt is completely seperated from the pinion. So hopefully the worm/bolt backed off the pinion verses the pinion bearing failing. Thanks to Clay Perrine for the great phone support and keeping me out of the deep end. This club continues to prove that it is made up of super folks. (IMG:style_emoticons/default/beer.gif) Attached image(s) |
jr91472 |
Sep 25 2004, 07:04 AM
Does anyone have a tip for removing the rear cover. I have removed all the bolts. I used a rubber hammer to lightly bang on the ears to break the seal between the end cover and the intermediate plate, but I can't get the end cover to let go.
Basically, how can I put force on the end plate without causing the intermediate plate to separate from the main case? Prying apart would be easy, but I am afraid of damaging the mating surface on the intermediate plate. Anyone?? |
Red-Beard |
Sep 25 2004, 07:06 AM
QUOTE(jr91472 @ Sep 24 2004, 08:54 PM) I can see that the 30mm bolt is completely seperated from the pinion. This is good news. It means the bolt was not tightented down properly and most likely not a bearing failure. You will need a new speedo worm drive in addition to the cover. And, while the tranny is apart, you and clay should really fix it. You should get a tail shifter core (maybe you old one) and re-work everything. Have you contacted the seller? James |
Red-Beard |
Sep 25 2004, 07:12 AM
Maybe a "little" more force. DO NOT USE GORILLA STRENGTH.
Most likely, the re-assembler used a non-drying gasket sealer to seal the cover. You could try prying with a long screwdriver, up the speedo drive hole. But I really thing you just need to keep working the cover. Make sure you really do have all the nuts off, but that is kinda obvious. James |
jr91472 |
Sep 25 2004, 07:38 AM
[QUOTE]
agreed Spoke to the seller, he is waiting to hear what all is damaged. |
jr91472 |
Sep 25 2004, 03:15 PM
Ok, got the end cover off. Now for the pics. First is the source of the hole - worm drive.
Attached image(s) |
jr91472 |
Sep 25 2004, 03:16 PM
Now the end cover. Note the scoring in addition to the hole. This is from the Guide Sleeve.
Attached image(s) |
jr91472 |
Sep 25 2004, 03:18 PM
Finally the back in of the tranny. Note the thrush washer apparently moved when the cover was taken off. Also, the Guide Sleeve was close to falling out once the rear cover was removed. Is sitting kind of loose in this pic.
Clay, PM is on the way. Attached image(s) |
Lo-Fi Version | Time is now: 7th June 2024 - 11:13 AM |
