Harpo |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None ![]() |
What is the best way to clean up my trans. I believe the case is magnesium is there a cleaning agent that I should stay away from?
Once it is clean what should I use to protect the trans and help keep it clean? Thanks David |
Scott S |
Small Member ![]() ![]() ![]() Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 ![]() |
I used simple green and lots of tooth brush sized wire brushes in varios stiffnesses. The brushes came in 3 packs at nearly every local auto parts stores.
After it dried for a few days I went over the whole thing again with just a new set of brushes (dry). Looks clean, but not over restored/polished. (sorry for the crappy pic) Attached thumbnail(s) ![]() |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
I use "Awsome" from the $ store! Works great!
Just spray it on, scrub it a bit, let it sit for a while and pressure wash it off....repeat! |
slothness |
It's business time ![]() ![]() Group: Members Posts: 110 Joined: 7-October 04 From: Valencia, CA Member No.: 2,906 Region Association: Southern California ![]() |
Everyone has an opinion on this. I used name brand EZ Off oven cleaner and a hard nylon bristle brush with a damp rag, my trans was coated in heavy crispy grime and it cleaned it beautifully. Then coat it with a liberal amount of Tectyl (waxy type spray on coating).
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Tectyl is crap. You need to reapply too often. See my 31 pages of note for my opinions on this (IMG:style_emoticons/default/smile.gif)
wingnut86 |
...boola la boo boola boo... ![]() ![]() ![]() Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States ![]() |
Doc,
There ya go again, understated as always. Stop beating around the damn bush and tell us what you realy mean... (IMG:style_emoticons/default/happy11.gif) |
slothness |
Yeah, I only mentioned something specific because the notes kinda say don't clean your tranz. If you do then search other forums for methods, or paint it. My trans was so caked with "road caca" cleaning it was a must cuz the last thing I want is overheating with all the money I put into that thing. The front of my trans is painted black, the intermediate plate and tail cone are Tectyl, reapplication is no biggie.
Dr Evil |
Pressure washing bad, tectyl bad, clean with Eazy Off good, paint good.
Simple? |
Jeffs9146 |
QUOTE Pressure washing bad (IMG:style_emoticons/default/agree.gif) If you are NOT opening it up to service it! |
bulitt |
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States ![]() |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
If doing a hand job, use a 2 inch round wire brush on a drill...
Puns galore. |
Harpo |
Yes I plan to rebuild at the Ohio trans clinic. quarter power wash was something that I was considering.
Thanks David |
Dr Evil |
If right before clinic, pressure wash ok. It is the water that gets in and sits that is the reason.
a914622 |
Member ![]() ![]() Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest ![]() |
I have used this method for a long time. Jacobs paint stripper and a power washer will make it look like new. I have a bunch of trannys in storage and before i put them away I clean them and put on a coat of LP3. Its the waxy shipping grease. sprays on like a thin honey and dries to a wax.
If its going in use I like the machine gray engine paint. Or black. jeff Ps Jacobs also cleans pistons |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,585 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
Would something like Gibbs penetrating oil work to protect it after cleaning? Isn't tact what some 911 guys use on their fans?
Dr Evil |
The Gibbs oil is something I am not familiar with, but Gibbs does make a protectant that some use (the name escapes me).
The only reason to use exotic preparations on your case is if you do not plan on cleaning it completely (IMG:style_emoticons/default/confused24.gif) If you remove the grease and dirt, just paint the dang thing. I am using a product from POR-15 that looks like brushed aluminum. |
Steve73 |
Photographer/Shade Tree Mechanic ![]() ![]() Group: Members Posts: 125 Joined: 2-July 11 From: Nashville Member No.: 13,269 Region Association: South East States ![]() |
What about painting it with Silver caliper paint. It's designed for high heat and is "chemical" resistant.
Drums66 |
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region ![]() |
.....Wire wheel & drill....Fuch,no....power wash easy/off or simple green.....
speaking from decades of experience!! |
speed metal army |
Waiting for the rain to stop... ![]() ![]() ![]() Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada ![]() |
I used some s100 cycle cleaner, works kickass! A brush in the spots the goo was super heavy helped too.
Richard Casto |
Blue Sky Motorsports, LLC ![]() ![]() ![]() Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States ![]() |
Tectyl is crap. You need to reapply too often. See my 31 pages of note for my opinions on this (IMG:style_emoticons/default/smile.gif) We all have our opinions regarding Tectyl (or equivalent). Short of painting, I challenge people to suggest a better solution. I have done some long term testing with... * Tectyl * Gibbs * No coating (bare metal after cleaning) Tectyl wins hands down. It is not perfect and doesn't last forever, but provides good protection. Painting is great, but everyone can't afford (or even want) to do it. So they need other options. To the OP question. Others have made good suggestions. I prefer non acidic/caustic solutions, but they can work if you don't go crazy. I would only pressure wash if you plan on opening it up right afterward. Be careful with using wire brushes. I don't use steel wire and even then only scrub by hand. It really comes down to putting in the time. Dental style picks are good for cleaning the hard to reach places. Richard |
Lo-Fi Version | Time is now: 5th July 2025 - 09:33 PM |
