Removing drive shafts |
PancakePorsche |
Apr 13 2012, 12:48 AM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
Planning replacing drive shafts this weekend. Is it necessary to remove HE's to get shafts out on a 1976 ? Looking to save time by not doing un-necessary work.
type47 |
Apr 13 2012, 05:51 AM
It should not be necessary to remove the HE's to remove the axles...
edit: However, I looked in the factory workshop manual 3.1-1/1 and step 2 is remove heat exchangers (IMG:style_emoticons/default/blink.gif) Can't say for a '75 but I've removed the axles from '73 & '74 w/o removing the HE's. I don't think ->74 and 75-> are that much different Cap'n? |
DRPHIL914 |
Apr 13 2012, 06:40 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Do you still have the 76 h.e.'s? I just rook my transmission out and the c.v.'s and did not take my exhaust off, but I have the backdated 74 h.e.s. you should not have to. But I had a hell of a time removing. My original h.e. so it could be a tough job if you choose that direction. If I were you I would take them out and back-date them. Get rid of those while you are at it.
PancakePorsche |
Apr 13 2012, 07:51 PM
[quote name='Philip W.' date='Apr 13 2012, 05:40 AM' post='1665590']
Do you still have the 76 h.e.'s? I just rook my transmission out and the c.v.'s and did not take my exhaust off, but I have the backdated 74 h.e.s. you should not have to. But I had a hell of a time removing. My original h.e. so it could be a tough job if you choose that direction. If I were you I would take them out and back-date them. Get rid of those while you are at it. [/quote I wish I could but I need the CAT. in California. Lucky me. |
Jeffs9146 |
Apr 13 2012, 08:32 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Taking off the trailing arms off and pushing the axcels out of them is much easier than trying to remove the them with the HE installed! It all depends on how long it has been since the last time they were apart sometimes it can be hard to seperat the CV's!
John |
Apr 14 2012, 11:39 AM
Removing the heat exchangers makes the job much easier, but it is not absolutely necessary. It is tight.
It's about a wash time wise. You can fight to get the axles out and then back in, or you can take the time to remove the heat exchangers.... |
Lo-Fi Version | Time is now: 7th June 2024 - 04:43 PM |
