ECU help, Loaner |
ECU help, Loaner |
Black22 |
Apr 16 2012, 02:12 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
Anyone in So Cal have a working L-jet ECU that runs a 6 pin AFM they can lend me to help me get my ride going? I can pick it up today and try it, then bring it back to you today after results, or buy it from you if it does work.
timothy_nd28 |
Apr 16 2012, 02:15 PM
I'm sure the Capn' has this. He posted something earlier about have a box overflowing with ECU's
Black22 |
Apr 16 2012, 02:48 PM
I hope he chimes in then.
I went through EVERYTHING else and it all checks out ok. It can only be the ECU or the harness. The harness was gone through my Jeff B. about 5 years ago though and there was continuity on all the tests that require you to go through the harness. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/type.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/barf.gif) (IMG:style_emoticons/default/sad.gif) |
Socalandy |
Apr 16 2012, 10:35 PM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
I have the harness and ECU from my 72 1.7 that worked when pulled for carb install
Not sure if that's a fit for you. Yes, I know nothing about FI in 914's |
timothy_nd28 |
Apr 16 2012, 10:43 PM
Yeah, it won't work. He has a Ljet 1.8L. If you have a 1.7L, most likely your ECU will be for a Djet system.
timothy_nd28 |
Apr 16 2012, 10:46 PM
Lo-Fi Version | Time is now: 31st May 2024 - 09:12 PM |
