So, what would it take to twin turbo my 3.6L engine? |
SirAndy |
Apr 19 2012, 04:43 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
What would it take to twin turbo my 3.6L engine?
There's a few obvious changes, but my guess is there's a lot more to it. Could any of the newer factory setups be adapted to fit my engine? (IMG:style_emoticons/default/idea.gif) |
ldsgeek |
Apr 19 2012, 04:45 PM
Member Group: Members Posts: 155 Joined: 27-June 10 From: New Hampshire Member No.: 11,885 Region Association: None |
Many cubic dollars. Other than that I got nothing.
mepstein |
Apr 19 2012, 05:18 PM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
What about a supercharger? Way less plumbing. No internal mods. 400hp. $7,500 (IMG:style_emoticons/default/biggrin.gif)
Attached image(s) |
JmuRiz |
Apr 19 2012, 06:02 PM
914 Guru Group: Members Posts: 5,433 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
What he said...I know TPC used to offer this 3.6 setup. Contact them for their thoughts (I know someone there if you need a name to drop).
ConeDodger |
Apr 19 2012, 06:04 PM
Apex killer! Group: Members Posts: 23,604 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Superchargers do make a delicious whine as they wind-up (IMG:style_emoticons/default/evilgrin.gif)
a914622 |
Apr 19 2012, 07:02 PM
Member Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest |
Doesn't the whine screw up the knock sensor?
Lets see a maga-squirt and some staged turbos, and a plastic seat cushion for easy clean up when you unleach the beast. Man that would be a lot of GO? jcl |
Mike Bellis |
Apr 19 2012, 07:09 PM
Doesn't the whine screw up the knock sensor? Lets see a maga-squirt and some staged turbos, and a plastic seat cushion for easy clean up when you unleach the beast. Man that would be a lot of GO? jcl Megasquirt is not sofisticated enough to run staged turbos. You need high end EFI stuff for that. Figure $10k for an engineered twin turbo system. And a full rebuild of your engine with all new internals. |
iamchappy |
Apr 19 2012, 07:11 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
All you need is one, two for cool factor only...... believe me....
Marty is running dual turbos he could tell ya... Exhaust turbo = free HP and would be cheaper than the supercharger. |
Mike Bellis |
Apr 19 2012, 07:14 PM
All you need is one, two for cool factor only...... (IMG:style_emoticons/default/agree.gif) I removed the twin turbo from my engine and went with a larger single turbo. Way easier to setup. You want look at a Motech system as they are used in turbo Porsche race cars everywhere. What's you budget? |
iamchappy |
Apr 19 2012, 07:15 PM
The new variable vane turbos act much like having two turbos in one, come on fast and smooth. One single hits hard and makes things interesting quickly..... (IMG:style_emoticons/default/biggrin.gif)
Attached image(s) |
SirAndy |
Apr 19 2012, 07:20 PM
iamchappy |
Apr 19 2012, 07:38 PM
Nice option.....better get busy only 8 months til the end of the planet. |
Mike Bellis |
Apr 19 2012, 07:40 PM
Then spend the $$$$$ for a complete setup with engine and ECU. Sell you 3.6 to help finance it. |
Elliot Cannon |
Apr 19 2012, 08:43 PM
Did Ammoy get a job? (IMG:style_emoticons/default/lol-2.gif) (Don't let her see this, she'll kick my ass) (IMG:style_emoticons/default/laugh.gif) |
Andyrew |
Apr 19 2012, 09:25 PM
If your going to keep your 3.6, Why twin turbo? Whats your HP goal? 450? 500? 600? 700?
There is no need to run twin turbos on 3.6l's that is plenty of displacement to run a pretty large single turbo with VERY little turbo lag. Using some of today's turbo technology you can get some pretty impressive numbers.. I'd say go with a twin scroll ball bearing turbo. With a new fancy inlet (like Precisions HTA). Im running a Comp Turbo CTB5356 on my Audi 1.8L and with full spool under 4k rpm's i'll be looking at well over 500hp with the boost cranked up. Maybe close to 600 on race gas. As it is now I have it at 10psi and its making ~ 330hp and has wonderful driveability. With 3.6L you could run a slightly larger turbo than that and tune however much HP you want and still have very quick spool. Besides, there is nothing like the feeling of a large single turbo that wants to go more.. Oh man.. Ask Mike... |
Mike Bellis |
Apr 19 2012, 10:06 PM
I think mine spools to quick. is that possible? I can get FULLLLL boost by 2000-2500rpm. It makes quick blips of the throttle really fun. Maybe I should let Andy drive mine?
Elliot Cannon |
Apr 19 2012, 10:23 PM
I think mine spools to quick. is that possible? I can get FULLLLL boost by 2000-2500rpm. It makes quick blips of the throttle really fun. Maybe I should let Andy drive mine? Maybe you should let ME drive it. (IMG:style_emoticons/default/laugh.gif) |
Mike Bellis |
Apr 19 2012, 10:39 PM
I think mine spools to quick. is that possible? I can get FULLLLL boost by 2000-2500rpm. It makes quick blips of the throttle really fun. Maybe I should let Andy drive mine? Maybe you should let ME drive it. (IMG:style_emoticons/default/laugh.gif) You can only drive as fast as you see, old man (IMG:style_emoticons/default/poke.gif) But maybe... Beats getting a mustache ride from you (IMG:style_emoticons/default/sheeplove.gif) |
r_towle |
Apr 19 2012, 10:43 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
For some reason I knew this was coming....
It may be easier to buy a turbo motor...IC them for 15k-18k online on Ebay once in a while. Call EASY...I bet he could find one. Rich |
McMark |
Apr 19 2012, 11:28 PM
Twin turbo might actually be easier on a 914/6 since there aren't any header (I know of ) that combine to a single pipe. So you could add a turbo onto the end of each header. Something like ottox914 did (build thread).
Plumb that directly to where you air cleaner sits now and then figure out the fuel injection situation. Something tunable would be my first thought, of course there are shops that seem to do amazing things with custom chips. I would love to see a header that turned up at the end of the engine, allowed the turbos to sit near the flywheel, and then continued (post turbo) over the axles and out the back. IMHO, plumbing is the easy part. FI is a tad harder.... |
Lo-Fi Version | Time is now: 31st May 2024 - 05:14 PM |
