Help (i.e. photos) needed of seam sealed areas |
Qarl |
Apr 20 2012, 07:39 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Hello fellow teeners.
I need some help. When my body was stripped (and subsequently crappily repainted) all of the seam sealer was removed, but not re-applied before painting. I'm talking the bumpy type that's around the floor plugs and stuff like that. So here's what I need... Can someone post photographs where the factory applied the sprayed on seam sealer in the following areas... Front trunk Rear trunk Cockpit floor pan and side rails Cockpit rear firewall I just need to rebuilt my reference library for the new body guy to fix everything. Photos can be of your call, original concouse weenie stuff, or other people's that you illegaly post without their consent! LOL Thx, Q |
Qarl |
Apr 20 2012, 07:51 PM
Found one via google... but I need to know where seam sealer might be down where you can't see (beneath the tail lights inside the rear trunk)
Attached image(s) |
Socalandy |
Apr 20 2012, 08:00 PM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
out of the backyard, hope this helps
Attached thumbnail(s) |
1970 Neun vierzehn |
Apr 20 2012, 08:07 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Are you looking to do early (hand applied) seam sealer, or the later sprayed-on application?
Paul |
Qarl |
Apr 20 2012, 08:15 PM
Are you looking to do early (hand applied) seam sealer, or the later sprayed-on application? Paul Thanks. As stated in the original post, the sprayed on type. (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/piratenanner.gif) |
Apr 20 2012, 08:21 PM
sprayed on.....this on a 1972
Attached image(s) |
Qarl |
Apr 20 2012, 08:27 PM
Awesome!
You got a front trunk pic too? The above is perfect! |
Apr 20 2012, 08:30 PM
two of the same '72 (I know this car firsthand....it's Pat Garveys')
Paul Attached image(s) |
Apr 20 2012, 08:36 PM
Your interior pic (bare) request is a bit harder to come up with, but I am looking.
So far this is it..... Attached image(s) |
Lo-Fi Version | Time is now: 31st May 2024 - 11:54 PM |
