| 914itis |
Apr 21 2012, 05:50 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
The car runs great as long as I don't hit 3200-3500 rpm. Same spot on all gears and all engine temps.I mentioned 32-3500 since I know that these old gauges are not accurate.
| jmill |
Apr 21 2012, 05:55 PM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Carbs or FI? Engine size, type and any other pertinent info would also help.
| poorsche914 |
Apr 21 2012, 05:57 PM
9fourteen ![]() ![]() ![]() ![]() Group: Members Posts: 3,151 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
| 914itis |
Apr 21 2012, 06:03 PM
Diet 2.0 leaker , if tps I have onee on the way .
| jmill |
Apr 21 2012, 06:04 PM
FI, I'm out. |
| falconfp2001 |
Apr 21 2012, 06:52 PM
Pancho Pantera ![]() ![]() Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
I'd say the TPS. I had the same symptoms once. By the third one I was able to get it working right. I never replaced the board but always intended to.
AA sells the board for replacement. |
| TheCabinetmaker |
Apr 21 2012, 07:02 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,377 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Yep, the traces are worn. Sometimes you can tweek the arms just a little to make it contact better on an unmarked part of the trace.
| 914itis |
Apr 21 2012, 07:09 PM
I ordered one from Dave sprinkle last week. I had a feeling it was causing some of my issues . I should have it soon .
| 914itis |
Apr 21 2012, 07:12 PM
| jim_hoyland |
Apr 21 2012, 07:13 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,080 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Does the L-Jet TPS have the same problem, or is it completely different ?
| euro911 |
Apr 21 2012, 07:56 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
Jim, they're very similar and are prone to the same problems.
| trfrick |
Apr 21 2012, 08:51 PM
Long Time Listener First Time Caller ![]() Group: Members Posts: 25 Joined: 28-August 10 From: CA Member No.: 12,113 Region Association: Northern California |
I had the same problem once and it was the rebuilt mps.
| davesprinkle |
Apr 21 2012, 09:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None
Does the L-Jet TPS have the same problem, or is it completely different ? Hi Jim, I'm going to disagree with the previous poster. The Ljet TPS is substantially different from the Djet TPS. The Djet sensor detects changes in throttle angle of roughly 2º. The Ljet sensor is only used to detect idle and wide-open throttle. -dave |
| euro911 |
Apr 22 2012, 01:31 AM
I stand corrected and recant my previous post.
I did additional research and found the following post from Sean Molloy: "the L Jet TPS is a 3 position contact switch that RARELY fails unlike the d jet 10 position 3 pole sweeper type.the unit used in the 1.8 has contacts that look like ignition points. clean them and the should work. they never fry because they are low voltage low current" I confused it with the difference types for the 1.7L & 2.0L D-jet systems. |
| bulitt |
Apr 22 2012, 05:02 AM
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Your car looks great Paul!
| 914itis |
Apr 22 2012, 08:39 AM
Thanks , I am happy with the outcome .
| jim_hoyland |
Apr 22 2012, 07:34 PM
Does the L-Jet TPS have the same problem, or is it completely different ? Hi Jim, I'm going to disagree with the previous poster. The Ljet TPS is substantially different from the Djet TPS. The Djet sensor detects changes in throttle angle of roughly 2º. The Ljet sensor is only used to detect idle and wide-open throttle. -dave Thanks Dave. Good info |
| underthetire |
Apr 22 2012, 08:14 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Or the mechanical advance in the dizzy is sticking. That's about where they go full advance I believe. Just a thought.
| 914itis |
May 22 2012, 08:39 PM
Update:
I rebilt my original dizzy using the vacum advance from another one with a broken ground, clean it up nicely, re-do timing and the issue was solved. I was able to raise the rpm on 1st 2nd and 3rd to 5000 for testing, hesitation is gone and the car sounds great. I was never able to go past 3900 before. Thanks to all my mentors here. |
| ConeDodger |
May 22 2012, 08:48 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,461 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
Pop the cover on the TPS. You will probably find it all gummed up in one spot. It does that because the RPM you are describing is right at cruise.
Take a good new pencil eraser and gently rub away the goober on the circuit board. Then cover it back up and check it out. It should be much improved. New replacement boards are available in the Member Vendor section of the World. Edit: I see you found Mr. Sprinkle on your own... (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 9th June 2026 - 03:45 AM |
