Fuel line replace, help. |
broomhandle |
Jun 3 2012, 10:51 PM
Member Group: Members Posts: 290 Joined: 26-June 09 From: Half Moon Bay, CA Member No.: 10,512 Region Association: Northern California |
Switching from old messed up FI to a carb.
Do I cap off the return fuel line? And I would like to do all new fuel line from tank to engine bay. It's that plastic line, would I just use a rubber line? And does it snake thru the frame? |
jeeperjohn56 |
Jun 3 2012, 11:39 PM
Member Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None |
I wouldn't use rubber thru the tunnel, buy the stainless steel fuel line's from CFR racing. He's in the vender's section. John
broomhandle |
Jun 3 2012, 11:43 PM
Is it all bent so it fits and is a easy install?
Otherwise what about just standard ss fuel lines? |
CrashDown |
Jun 3 2012, 11:53 PM
Fake Carbon Fiber MASTA! Group: Members Posts: 159 Joined: 8-June 09 From: Union City, CA Member No.: 10,453 Region Association: Northern California |
jeeperjohn56 |
Jun 4 2012, 02:39 AM
The one's from CFR are pre bent, If you go to his web site you can see a picture..
ape914 |
Jun 4 2012, 11:59 AM
red locktite Group: Retired Members Posts: 240 Joined: 7-February 11 From: In front of a computer Member No.: 12,676 Region Association: None |
you can get original looking plastic line from industrial suppliers such as Mcmaster.
ClayPerrine |
Jun 4 2012, 10:00 PM
Life's been good to me so far..... Group: Admin Posts: 15,515 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Please do NOT put plastic line back into the car.
I watched my wife's 914 burn due to bad plastic lines. If you are taking the time and effort to replace the lines, use stainless steel. Here is my writeup on how I did the fuel lines in my six conversion. The kit sold by Chris Foley is just as good. |
Rotary'14 |
Jun 4 2012, 10:28 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
I can sell you one pre bent line in either 8mm or 9.5mm. I have a bunch of other fuel line stuff too.
Lo-Fi Version | Time is now: 8th June 2024 - 09:28 AM |
