OT: Venus Transit, is a welding helmet safe? |
zymurgist |
Jun 5 2012, 03:26 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Specifically, is an electronic welding helmet safe to look at the sun?
Katmanken |
Jun 5 2012, 03:51 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Short answer, I wouldn't try it.
Take a cardboard box, put a pinhole in it (aka pinhole camera), and aim the hole at the sun. Put a sheet of white paper below the hole so that the sunlight beam coming through the hole shines on the paper. Move the the sheet of paper farther away from or closer to the hole to set the image size. Enjoy the view. No danger in doing that. |
Jeffs9146 |
Jun 5 2012, 03:57 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I have always used 3-4 layers of exposed film taped to the end of a small set of binoculars! The welding helmet was not dark enough (at least mine) to completly cut through the glare and you would not be able to see the dot of Venus!
Rand |
Jun 5 2012, 03:59 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Lenses are rated. If I recall, 12 is safe. But that's full solar. If it seems bright, then don't. Pretty simple really.
If you look, then look away, then see remnants.... You are DOOMED. Doomed I say. |
Rand |
Jun 5 2012, 04:01 PM
After the recent full on eclipse, you might as well watch this one with a pinhole shoebox. Meh.
zymurgist |
Jun 5 2012, 04:07 PM
No eclipse for east coasters.
When we are lucky enough to get one, it's usually cloudy. |
r3dplanet |
Jun 5 2012, 04:42 PM
Senior Member Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None |
Twelve is still a little unsafe. You can use #14 welding goggles (rare) or buy solar-certified specs prior. The exposed film trick works also. I'm looking at it now with both #14 goggles and solar-certified specs and even the #14s are hurting a little.
Steve |
Jun 5 2012, 04:52 PM
914 Guru Group: Members Posts: 5,613 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
My kids bought cheap special cardboad framed glasses from amazon. Work great. We are watching the eclipse now.
'73-914kid |
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Most dedicated welding stores sell #14 masks if you can find a store nearby. The problem is, most are still out of stock from the recent solar eclipse.. #14 are fine for the quick glance at the sun I'd say.
SLITS |
Jun 5 2012, 05:13 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
I used my Harbor Freight Shield ... worked great. Shiny disk, black dot. I am not going to stand there and watch all 6 hours / 40 mins of transit time.
Now that the thrill is over I guess I'll go back to my totally dull life. Oh, the auto-darkening welding helmet didn't get dark enough. |
mrbubblehead |
Jun 5 2012, 05:17 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
mine wouldnt turn on. i had to use my old school regular lens.... its pretty cool to see another planet.
SirAndy |
Jun 5 2012, 05:26 PM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Take a cardboard box, put a pinhole in it (aka pinhole camera), and aim the hole at the sun. Put a sheet of white paper below the hole so that the sunlight beam coming through the hole shines on the paper. Move the the sheet of paper farther away from or closer to the hole to set the image size. Enjoy the view. No danger in doing that. Did just that, you can even see some sunspots! (IMG:style_emoticons/default/cheer.gif) |
SirAndy |
Jun 5 2012, 05:29 PM
Adjusted for the weird camera angle ...
Attached image(s) |
SLITS |
Jun 5 2012, 05:30 PM
And if you are lazy like me, use this link:
See Venus Transit the Sun and use the University of New Mexico feed ............ |
andys |
Jun 6 2012, 09:50 AM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
76-914 |
Jun 6 2012, 12:09 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I watched the last eclipse thru a Lay's Chip bag (mylar). A party balloon (the silver foil type, also Mylar) works, also.
ChrisFoley |
Jun 6 2012, 01:16 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Specifically, is an electronic welding helmet safe to look at the sun? Simple answer - yes. Auto darkening helmets provide full UV protection even in the light state. The only problem if the lens isn't dark enough or doesn't switch to the dark state, is your eyes will get tired of the brightness quickly. There are no lasting negative effects. |
Rand |
Jun 6 2012, 04:05 PM
Woah. Depends on the darkening level. My "electronic welding helmet" rocks, but....
You have to adjust the darkening level with a knob. And even at full dark, some critics will still give you grief. Mine was fine. Like I said before, can you look at it without it seeming too bright, then look away with no artifacts?? There's no substitute for common sense. Thought I'd share this for fun.... http://gizmodo.com/5916350/this-amazing-sp...dium=socialflow |
zymurgist |
Jun 6 2012, 05:41 PM
It was cloudy here. (IMG:style_emoticons/default/sad.gif)
ChrisFoley |
Jun 6 2012, 06:07 PM
Woah. Depends on the darkening level. My "electronic welding helmet" rocks, but.... I used to have an auto darkening lens that was real touchy. It would switch if there was an incandescent bulb nearby. And I know it switched when aimed at the sun. I guess I don't have that lens anymore though. All arc welding lenses provide 100% protection from UV, including auto darkening lenses regardless of their darkness level. An electric arc is obviously brighter than the sun if the sun won't even make an a/d lens switch to dark. Just for hahas, today I tried looking at the sun with my auto darkening helmet. It wouldn't switch to dark state so I couldn't really look at the sun directly. But I did anyway... it was too bright...I had to look away after only a few seconds. There was a distinct, but not too bright, afterglow in my eyes for a few seconds but there were no lasting effects. |
Lo-Fi Version | Time is now: 8th June 2024 - 04:36 AM |
