Pad under the rollbar, Won't come off |
StratPlayer |
Jun 11 2012, 02:16 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Need to get the rollbar pad off the rollbar. I have all the screws out of the rollpad, screws in the bottom and the screws that are in the front of the pad. The pad won't budge, Is there somthing I'm missing in this process of removing the pad?
This is the pad that is under the rollpad. |
markb |
Jun 11 2012, 02:23 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
The side pads have to come out, too. Make sure there aren't "extra" screws in there. I think I remember the holdowns need to come off too.
Porschef |
Jun 11 2012, 02:24 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Need to get the rollbar pad off the rollbar. I have all the screws out of the rollpad, screws in the bottom and the screws that are in the front of the pad. The pad won't budge, Is there somthing I'm missing in this process of removing the pad? This is the pad that is under the rollpad. That should do it, along with a good yank, starting on one side. I had mine off a coupla weeks ago. You may need to remove the latches first... |
76-914 |
Jun 11 2012, 02:36 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If you don't have a screw for every hole then you skipped one. They can be a PIA to "feel". (IMG:style_emoticons/default/beerchug.gif) When you have them all out, it removes out easily.
Dave_Darling |
Jun 11 2012, 05:20 PM
There may also be screws in the top where the targa latches are. They were small, but a PITA if I remember correctly!
--DD |
pete000 |
Jun 11 2012, 06:48 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
I read that the latches have to be removed first and installed last.
http://www.google.com/imgres?imgurl=http:/...sbfd&itbs=1 |
Lo-Fi Version | Time is now: 8th June 2024 - 02:09 PM |
