Does the speedo or clutch cable go, in the hole on the engine carrier? |
chris914 |
Oct 17 2004, 10:02 PM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
Hi,
Does the speedo or clutch cable go in the hole on the engine carrier on 73-76? Thnaks! |
scotty914 |
Oct 17 2004, 10:11 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
i have my speed do cable in it
scott |
JB 914 |
Oct 17 2004, 10:14 PM
Daddy! Finish my car NOW!!! Group: Members Posts: 1,593 Joined: 26-September 04 From: Garden Grove, CA Member No.: 2,831 |
I think that's what it's for, but, you don't have too do it that way. I ran my speedo and clutch cables and used some zip ties to secure them away from the engine and from hanging low.
skline |
Oct 17 2004, 10:16 PM
They both will fit there but I always run the clutch cable through there and the speedo cable above it and tie them together with ties. If you run the speedo cable first you can put the clutch cable through also. Its up to you just make sure they are not against or near the exhaust.
Elliot_Cannon |
Oct 18 2004, 12:01 AM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
All the above is true. Just make sure that you use heat resistent wrap or use tie wraps to keep the cables off the exhaust. I'm using headers and it takes some creative tye wrap work to keep the cables from melting.
Cheers, Elliot |
TheCabinetmaker |
Oct 18 2004, 06:27 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Your clutch cable should have a rubber sleeve on it about 8" long. That sleeve goes thru the hole in the engine mount bar. It takes up the entire hole, and holds the cable securely in place.
smg914 |
Oct 18 2004, 01:41 PM
Sahara Beige Steve Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
QUOTE(vsg914 @ Oct 18 2004, 04:27 AM) Your clutch cable should have a rubber sleeve on it about 8" long. That sleeve goes thru the hole in the engine mount bar. It takes up the entire hole, and holds the cable securely in place. (IMG:style_emoticons/default/agree.gif) |
TheCabinetmaker |
Oct 18 2004, 01:44 PM
I was in my local P-car shoppe today and they had a new 8mm cable hanging on the wall. The sleeve was only two inches long. (IMG:style_emoticons/default/wacko.gif)
smg914 |
Oct 18 2004, 01:52 PM
I just went out to the garage and measured the one on the Sahara Beige 914 and sure enough, the enlarged sleeve is approximately 2 inches long.
Lo-Fi Version | Time is now: 1st June 2024 - 05:07 PM |
