1973 harness resistor - what is a fair used price? |
jimkelly |
Jun 17 2012, 12:01 PM
pic
pn seems to be - 039 971 762 A http://members.rennlist.com/pbanders/DJetParts.htm jim (IMG:style_emoticons/default/popcorn[1].gif) Attached image(s) |
Mike Bellis |
Jun 17 2012, 12:24 PM
$5
It is too easy to build a 270 ohm resistor to replace it. If you found NOS, then $$$ is the limit of the buyer. |
jimkelly |
Jun 17 2012, 12:26 PM
thank you : )
Mike Bellis |
Jun 17 2012, 12:31 PM
Here is a good solution...
http://www.mouser.com/ProductDetail/Vishay...Clx32trgRbBc%3d or this http://www.mouser.com/ProductDetail/Xicon/...252bGlMBjbxo%3d Unless you are the one selling the used one... (IMG:style_emoticons/default/biggrin.gif) |
Mike Bellis |
Jun 17 2012, 12:33 PM
Dave_Darling |
Jun 17 2012, 12:36 PM
IMHO, not much. It's just a resistor with spade lugs on each end. The one pictured doesn't even have the plastic box over the one end.
I can make a functional equivalent for about two bucks and ten minutes worth of work. --DD |
Lo-Fi Version | Time is now: 17th June 2024 - 03:55 AM |
