t collins |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None ![]() ![]() |
Assuming the flywheel is within specification would you consider it junk or still usable?
Thanks, Tom ![]() |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Teeth aren't broken off, so it should be good to go. Bendix gear wasn't meshing deep enough or not retracting far enough. Should have made one hell of a noise.
The ring gear can be machined off and a new one welded in if you are so inclined. |
t collins |
Teeth aren't broken off, so it should be good to go. Bendix gear wasn't meshing deep enough or not retracting far enough. Should have made one hell of a noise. The ring gear can be machined off and a new one welded in if you are so inclined. Thanks Slits, I purchased this 901 flywheel as seen for my six conversion and was told it would be OK but was gun shy just the same. |
Lo-Fi Version | Time is now: 31st July 2025 - 10:40 PM |
